Pc card, how to install - Computers & Internet
  • 68 Answers
kindly specifies what card is..
Posted on Aug 04, 2008
First, shut down the computer. Next, you will need to locate an unused expansion slot and then determine which type it is. Most newer PC's have "PCI" and "PCI express" slots (there are others). See the image below to help you identify the slots in your PC.
Choose a sound card that will fit one of these unused slots. Read the directions with the sound card. Some will have you install software first - others want the card installed first. Install the card into the slot and secure in slot with screw or clamp used by your PC and software in the order instructed.
You can also install a USB sound card instead of an internal type. This is required if you do not have an available slot or if you are not comfortable opening the PC. Most PCs with sound cards built into the motherboard will automatically be disabled when a second card is introduced to the computer - USB type or otherwise. If yours does not, you may have to disable it in the BIOS or physically remove to old sound card installed in one of the expansion slots.
May 07, 2014 | eMachines Black ET1352G03w Desktop PC with...
How do i install video cards in my emachines ET1352G-03W?
Your machine will accept a PCI-e x16 Graphics card. If you are going to go to high high-end, high-power card, ensure that you have the proper power connectors for the card. Mainstream video cards are powered from the PCI-e slot itself. Also, be advised that your machine only has a 220W power supply, so high-end cards may draw too much power from an already anemic source.
To install the new card, simply power off the PC and unplug it. Open the case and locate the PCI-e slot (closest to Power Supply). Take out the proper blank at the rear of the machine to allow the card to be installed. Install the card and secure it with a screw (or whatever means the case provides). Hook up the card's power connector (if equipped). Secure the case. Move your monitor's cable from the onboard video connector to the one on the new card. Power up the PC and watch the bootup. The Operating System should detect the new graphics card and will install, at a minimum, a generic driver for it. To install the drivers supplied with the card, install the CD/DVD and run the install setup program.
Dec 09, 2013 | Computers & Internet
Can't install drivers for GeForce GT 430. "Graphics Adapter Not Found."
I am assuming that your PC is working alright connected to the onboard graphics port.
Make sure any supplementary power connectors to your video card are in place, and the card is firmly inserted into the PCIE slot.
If you try these two items with no results, you might try installing the card in a known working PC. It could be a problem with the card itself.
Mar 24, 2012 | PNY GeForce GT 430 Video Card Bundle
Installed a Graphics card EVGA 6200 AGP 8X in my PC HP Media Center PC m370n now keeps showing failure notice
Did you install the drivers for the Graphics Card before you plugged the card into the computer? If not, remove the graphics card and reboot using your old video connection, install the driver then install the card and plug your monitor into the newly installed card. If you still have an issue try booting into safe mode.
Mar 19, 2012 | HP Media Center Photosmart PC (M7160N) PC...
New graphics card installation won't work. during start-up it does not find this piece of hardware, even though the fan on the card is running.
Hi klaas_smit_w,
You might have forgot to install the graphic card driver.
But first, make sure that the graphic card is installed properly in the slot of the motherboard.
Restart your PC and your PC must detect your graphic card immediately.
Install the driver of the graphic card and reboot.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 29, 2011 | Acer Veriton M264-EC1200C Dual-Core E1200...
Install a new sound card
turn off pc,open side of pc,install sound card in one of the open pci slots,close up the side,turn on the pc,windows will detect new hardware,put in the driver cd that came with the card and it will install it and should let you know if the drivers were successfully installed,restart the pc if told so
Feb 09, 2011 | Computers & Internet
Couple days ago my pc infected, antivir did not help recover my pc, so i formated the pc, after xp installation My X600 graphic card freezes as soon as star running any game and freezes all system. Driver...
Try this reformat your pc again without using your video card, after installing Operating System (XP) instelled your motherboard software and then shut down your pc. Put the video card in its place and power on your pc, click add new program as it may pop-up after it detect your new hardware.Installed the video card software and restart your PC.
Aug 16, 2009 | Computers & Internet
Verizon pc card problem
take out the card and uninstall anything you already installed. Reboot and run the install cd again until it either
a: finishes the install
b: asks you to put the card in.
Do not put the card in at any point prior to (a) or (b)
May 29, 2009 | Toshiba Satellite A135-S2276 Notebook
Installed PCI-e vid card
U need to insure that the new Vid card is compatible to Ur pc. Does the pc power up without the new Vid card? If so it sounds like the card may be defective and shorts out the pc power supply.
Apr 01, 2008 | Sony VAIO VGC-RB42G PC Desktop
Hi You can`t install applications on the memory card,you have to install it only on your phone memory. Good Luck
Aug 23, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
