Question about Garden
My grandpa gave me a Modern Angel Mascot gun shaped lighter that will throw a spark everytime but when I fill it with fuel you can hear the gas leaking and still a flame will not be given from the barrel. What can I do to fix this?
  • 14 Answers
SOURCE: Mr Heater MH75KT - won't start with diesel
If the MH75KT is the correct model, then it is a Kerosene only heater. Fuels, like oil and diesel all have different ignition points.
http://www.mrheater.com/upload/newsletter/70276_MH_HS_50_75_125_175_210KT_REV%20A.pdf
See page 3 of the manual.
Posted on Feb 04, 2008
escapement
  • 2334 Answers
SOURCE: Colibri lighter
Usualy there are screw at the bottom.
If there are no screws at all. that means the lighter is assembled in 'click-on' way and you have to use your imaginary engineering skills.
Start with a part which looks attached to lighter the last.
Posted on Dec 21, 2008
soloxilu
  • 65 Answers
SOURCE: I HAVE 1996 GSXR 750 WITH EXTREMELY LOW MILEAGE
If its a slow leak. Yes Normal. If its pouring out. you might want to check your fuel lines. If it continues to come out you should replace your gas lines immediately.
Posted on Jul 08, 2009
  • 12 Answers
SOURCE: fuse blown on cigarette lighter Saturn 2001
It sounds like you have a bad charging cable for the GPS or the cable is overloading the cigarette lighter.
The cigarette lighter is designed for less power then a 12v power outlet.
Therefore it is easy to blow the fuse for the cigarette light if you install something that draws too much power.
Posted on Sep 26, 2009
  • 494 Answers
SOURCE: I have a full propane tank. I bbq'd about 3 weeks
You may have turned the gas tank valve on too fast. Turn it back off, disconnect it and reconnect it. Then very slowly turn the valve back on. Light one burner at a time and turn to low before lighting the next. If you are hearing and smelling gas with the tank on but all grill knobs off, don't use the grill. You may have a leaking grill valve, regulator or hose. If you are only smelling gas with the knobs on, it's possible you have a clogged burner or orifice from bug nests, spiderwebs, etc and need to clean it out first. Hope this helps. Douglas
Posted on Jun 13, 2010
Fuel Fiiling
You should pick a different gas station. Perhaps one with a working fuel pump. The fuel gun has a valve in it which tells it if your gas tank is full or not. If that pressure valve in the gun isn't working properly, it will always think that your tank is full and stop the pump.
Jul 27, 2013 | Car Audio & Video
Where is the spark plug on a Paslode 250ii finish nail gun?
GO TO TOOLS DIRECT.COM THE SPARKPLUG IS # 11 UNDER THE END CAP.BUT MAKE SURE YOUR SAVETY IS OK.THE SPARK UNIT ASSEMBLY IS #20 IN THE HANDLE.
Jan 30, 2013 | RTO Paslode 902000 IM250 Ii Cordless 16...
Hello,I have Mac 110 model#600016c It`s in need of a little TLC The saw is about 25yrs.old and has never hadany work done on it.I need to know what the spark plug gap should be and what the gas/oil mix...
Spark plug gap should be: 0.020" and the fuel to oil ratio is 40:1. Be sure to use fresh fuel and a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Mix well in it's own container and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 01, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Playing modern warfare 2 and my system freezes everytime i complete a mission i cant do anything after the game has ended during the game i can not hear most of the audio just the gun fire
i think your player doesnt hav the memory space to deliver all the sounds ...the other games r clear means problem with warfare2 only...if your problem continues u try to check this site your problem will get cleared click hear
Nov 04, 2010 | Sony Playstation 3 (PS3) Console
Filled with gas/oil mix and won't start. Was running fine 30mins before. No issues at that time.
Remove the spark plug and test for snappy blue spark. If ok, pour a little fuel mix into the plug hole and try for start. If it pops several times, check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines and the primer bulb. Did you make sure that you used proper mixing of the fuel/oil? Be sure to use a modern synthetic saw oil with fresh fuel at the required ratio and use it's own can for mixing/storage. Shake the can thoroughly just before filling the saw. Hope this helps!
Sep 05, 2010 | Garden
What year and by who it was made
Guns marked as Witte's Special were PROBABLY made by Iver Johnson, and were marketed by Witte's Hardware in St Louis. A lot of hardware store brands made exact copies of famous guns, they looked great and they fooled a lot of people. The famous Westly Richards, was W. Richards, and was about $600 cheaper. LC Smith, was AC Smith, again, fooled a lot of people, anyway, I couldn't find the date of your gun, I believe it was a .410 shotgun, and wasn't too old when your grandpa got it. They are not worth very much. I'm surprised to see a serial number on that, most old guns didn't have numbers at all.Hope this helps.
Mar 13, 2010 | Remington Shotgun Mount 12Ga Lh, B Square...
Did an oil change, filled gas tank, put in GUMOUT, 1999 Jeep GC
If you put a fuel cleaner additive in the tank I would change the fuel filter. I believe on this model it is located in the frame just ahead of the fuel tank on the drivers side. Any foreign material cut loose from inside the tank from the cleaner often clogs the filter.
Jul 15, 2009 | Jeep Grand Cherokee Cars & Trucks
91 buick regal wont start
maybe swallowed a fur ball... put alot more gas in... 5 or more gallons and retry... with full charged battery
Oct 29, 2008 | 1991 Buick Regal
Garden Logo
218 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
