Question about Coldtech 48 cu. ft. / 1359 liter Upright Freezer CFD-2F
I recently purchased a used Coldtech CFD-2F Freezer. It ran fine for 1 day and then the control panel went out. It operated fine for about 3 days but now the compressor isn't running either. The lights come on inside the freezer but the fans up top aren't running.
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Posted on Jul 06, 2008
  • 1252 Answers
SOURCE: Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
Posted on Oct 24, 2009
  • 1252 Answers
SOURCE: cabinet is warm....where is the fuse located?
http://www.ascendmfg.com/PDFs/CT/CFD-1R,CFD-2R,%20CFD-3R.pdf
http://www.ascendmfg.com/PDFs/CT/CFD-1F,%20CFD-2F,%20CFD-3F.pdf
check both of these. they are the wiring diagrams that show where the fuses are in the circuit.
Posted on May 17, 2010
  • 884 Answers
SOURCE: J2GF-40S ColdTech display freezer merchandiser no lights come on
Sounds like a loose wire since the move. Check you have power at the switch (in and out). If you have, check the starters and ballasts
Posted on Apr 20, 2012
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
Freezer runs for approx. four days with operation normal. Then the temp. panel of front door displays a symbol that looks like a short L followed by a period. Then the temp. gauge and the interior light...
From what I read, the "L." that you see on the control panel indicated that the controls have been locked. According to the manual if you hold down the "alarm reset" button for 3 seconds the "L." will disappear allowing you to control the temperature again. I don't as of yet know what is causing your overall problem though...
Nov 04, 2013 | GE FUF14SVRWW Upright Freezer
Freezer stays around 23 degrees, freezer guy says motor is frozen and wants us to unplug unit again (2nd time this week)
23 degrees definitely no good. Your getting some refrigeration though so compressor probably OK. Could not be seized. This may not be a hermetic system .you may have lost some refrigerant.But sounds more like your not defrosting .Have freezer guy check for manual defrost switch or defrost timer .
Re post with more information for more help
cheers
Aug 18, 2011 | Coldtech 48 cu. ft. / 1359 liter Upright...
Purchased ColdTechCommercial Freezer CFD-3F from private seller. Freezer was used for 9 months then sat in a garage for almost two years. Freezer turns on and runs, but doesn't cool at all- in fact,...
Hose underneath is probably for condensation and defrost water. If the compressor is not coming on, there is a good chance it is the thermostat. There is always the possibility that there is a refrigerant leak and it leaked down over the 2 year period. This is where I would start.
Jul 08, 2017 | Coldtech 72 cu. ft. / 2039 liter Upright...
My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
May 31, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer switces off sporadically after periods of 20 to 10 days.
If this is a frost free refrigerator have the defrost timing unit checked out. It may well be sticking in the defrost position.
Nov 25, 2008 | Freezers
Evaporator freezes up
No model # .. Im assumeing its frost free.. so that means a defost problem.. heaters, defrost themostate or timmer.
Aug 30, 2007 | Coldtech 21 cu. ft. / 595 liter Commercial...
Coldtech 48 cu. ft. / 1359 liter Upright Freezer CFD-2F Logo
143 people viewed this question
Top Coldtech Freezers Experts
Dennis Boxerman
christian nielsen
Are you a Coldtech Freezer Expert? Answer questions, earn points and help others
