Question about Kenwood Excelon DDX-7015 Car DVD Player
Kenwood dnx9140 unit ejected cd and now the anti theft light is blinking. Unit not booting. what is the problem
  • mmcphaul603 Mar 27, 2011
    who has the answer
3 Suggested Answers
SOURCE: kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
Posted on Mar 26, 2008
  • 111 Answers
SOURCE: DNX7100 Security Code Password
While code request mode,point the remote control to the unit and enter this code 55222277or 552222777(depending the remote contro you are using)(try to press the numbers that faster you can) that is way you type KCAR from the remote control.
you will not see any change on the screen while you entering the number,only when you enter the last number the unit will go to standby mode.
if you make a mistake,reset the unit and start all over again.
let me know if works
thank you
Posted on Nov 17, 2008
Cd jammed won,t eject
Hi.
Try pressing repeatedly the eject button on the on dash player while turning on the stereo at the same time. If that does not work disconnect battery terminal for one minute to reset the electrics and try again pressing eject repeatedly on startup. Make sure that you have the stereo anti theft code if needed before disconnecting the battery.
If that does not work, then the unit must be disassembled. The car stereo must be removed from the dash. The unit must be disassembled removing screws at back and bottom and undoing metal casing clips. That will reveal the CD drive allowing to remove the disk.
Regards.
Ginko
Sep 14, 2011 | 2006 Pontiac G6
Asking me for code after i took the batteri out and put back in
This is the anti theft thing. You will need to get the code to activate it. You MAY have to go to the vendor that installed the unit.
Mar 25, 2011 | Kenwood KDC-MP238 CD Player
I bought a car from a car auction and it had a kenwood dnx9140 but when i turned it on it said enter security code but i dont know it because it was in vehicle that i bought , is there a bypass or default...
Probably not, you can buy security codes online, you just need the serial number off the head unit so you may need to get it out,
have a look here fore some head unit removal guides ;
www.carheadunit.co.uk
Oct 29, 2010 | Kenwood Car Audio & Video
The touchscreen on my kenwood dnx9140 stopped responding. how do i correct this? the unit is only 8 months old
There is a software update you need to download from garmin.com to harddrive and then paste to a SD memory card and use to update the unit.
Hope it helps!!!
Sep 22, 2010 | Kenwood Excelon DNX9140 Car DVD Player
Error 99 appears, unit is draning battery and cds have jammed up. where can i get another unit from apart from genuine as they are too expensive due to the climate control!
Hi.
If this is a Kenwood, then Error 99 means the following:
• E-99: Changer malfunction, disc may be caught in machine or changer requires service.
Before replacing the unit try disconnecting battery for two minutes (ensure you have car anti theft code). If that does not work, then the unit must be taken apart, there is a disk stuck or a mechanical problem.
Regarding replacement, to find one you need to post details on make and model. Ebay is a good source for second hand factory replacemnts. Here a generic list.
Shopping results for cd changer kenwood
About
Aug 09, 2010 | Car Audio & Video
My Kenwood KDC-MP232 entered "protect" mode, & I do't know why
This unit has an anti-theft program that is activated when a code is programed.
At this point forward, the power circuit is monitored, thus when the power is disconnected or drops below 12VDC it shuts down and the code must be entered to reactivate the unit and its functions.
Other circumstances that might trigger the anti-theft shut down are...
Bad power or ground connection to head unit.
A weak or faulty battery/alternator.
A blown fuse.
A sudden power surge, as happens when jump starting another car.
As for your personal 4 digit code, I cant help you with that but some high-end car audio dealers offer a diagnostic service that can reset a coded/locked out unit.
Good luck
Aduz
Mar 23, 2009 | Kenwood KDC-MP232 CD Player
Cd stuck, discread on display
If you can access the in-line fuse on the constant 12+ volt lead that powers the units memory. Remove that fuse and wait 5 min. then replace it. This should reset the unit, allowing you to eject the CD.
Note: If the anti-theft code has been enabled, you will need to input that code in order to operate the unit.
If the CD still does not eject, it may be jammed/binded up. thus requiring dis-assembly.
Good luck...
Feb 23, 2009 | Alpine CDA-7892 CD Player
Help! My CD is stuck and receiver will not power up!
It sounds like the head unit is going bad. If the CD is not that important to you dont worry about it. Also you may want to check the fuses behind the head unit. Also make sure the 12 V+ Memory backup, ground, and Ignition Wires are hooked up correctly. Well, the ignition probably is, but you never know.
I hope this is helpful!
Aug 14, 2008 | Kenwood Sirius KDC-MP225 CD Player
Kenwood Excelon DDX-7015 Car DVD Player Logo
71 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
