Small and black color with red light - Computers & Internet
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 141 Answers
You check your system to nearest help centre
Posted on Mar 27, 2011
Tail light wire colors
Hi Anonymous,
Black=Ground
Red=Brake light
Yellow=Tail light
Have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 24, 2013 | Harley Davidson Motorcycles
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
Need to know what color wires run my mass air flow sensor in my 93 maxda mx3 1.8l should be 2 wires what color and where to find then
You can pick up a Haynes manual. They have all necessary diagrams in them, including electrical schematics.
Regards,
matt
Sep 15, 2009 | 1993 Mazda MX-3
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
Amana dryer, changing out the electrical plug from 3 to 4 prong
For example; Green wire goes to green screw on machine. White in the middle, red on left, black on right. (observed small color coded wires connecting in back-ground as well.)
In general, each color should match. Meaning, white with white.
Jan 27, 2009 | Dryers
Sony KP-511HW40 fleshing with green color and shuts off
this is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
I bought the LG LHT854 and i dont know how to connectthe speakers because i dont know which ones are the front speakers and rear speakers, all 4 speakers are the same and i dont know how wich is wich..
All four of the small speakers are identical, the original speaker wires are color coded. the very ends are all black and red, corresponding to the black and red connections on the back of the receiver and on the speaker, and there is another color band lower on the wire, which corresponds to the color on the receiver speaker connectors that details front right, front left, rear right, rear left, center, subwoofer.
If you are using standard speaker wire, it has two colors. Pick one for the red, and one for the black.
Just be consistent and connect all speakers the same at both ends (Copper color to plus-red / silver color to minus-black)
Dec 24, 2008 | LG LHT854 Theater System
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Installing
not sure w/ this one, but is it blinking too fast on printer, the check color and black ink cartridges? and if yes what is the color of the light, is it yellow or red, and is the on and off lights, flashing?
-black and color blinking fast - install printhead
-black and color blinking slow - no cartridges installed
-on and off blinking black and color steady lights, calibrate
-hope this helps, or else contact kodak
-xoxo
Apr 11, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
On the Screen Red pixels comes in the background
hi
if you are see red pixels then your monitor haveing LCD Panel problume.
thanks
Ashok
Jan 14, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Computers & Internet Logo
13 people viewed this question
Alun Cox
David Payne
David Payne
