I have a Moster surge protector and I hit the reset button and it won't turn back on
    Master:
  • 403 Answers
Check your breaker, maybe that popped
Posted on Mar 27, 2011
Soundbar will not turn on
1. Check the power cord is plugged in properly by removing it and replacing it. 2. Try a different outlet on the surge protector.3. Most surge protectors have a reset button, try resetting it.
Is the sound bar the only device plugged into the surge protector?
Oct 25, 2012 | Vizio VSB200 40" Soundbar - SRS...
Tv will not turn on with remote or botton on side
the tv was on a surge protector line, what i notice that i had it plug in a cheap surge protector when i pull from wall i notice the adapter were burn and the cheap surge was burn at that time when i go to cut tv on i could hear a surge like sound. i tried to put it in another plug it wont come on, i open back of tv looking for fuse i could not find it or reset button can solve this problem i hit input button on side it still wont come on. i do not think there is any problem with picture it has something to do with power.
Aug 17, 2011 | iLO LCT32HA36 Television
I was watching my tv when my son hit the reset button on my surge protector..now my tv will not turn on. Any ideas?
Turn everything off, the tv the power and make sure the button is not active at the moment. Some surge protectors do come with a fuse but when you turn the surge protector back on itself make sure it is recieving power, there is usually a red light on the switch while recieving power. Then try again once you know there is power to it.
Feb 06, 2011 | Vizio E370VL 37 in. LCD HDTV
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
My daughters xps 200 won't start, she presses the button and nothing. She has checked the surge protector that it is pluged into and it is OK... is there a reset button is there was a power surge??
most surge protectors have some sort of on/off switch and a reset button. If there was a surge then you would need to pres the reset button to get the surge protector to function again. If there was no surge then try using the on/off switch on the surge protector to see if that helps. Also try simply unplugging the power cord from the back of the desktop while the computer is turned off. This will sometime also help.
Oct 12, 2009 | Dell XPS 200 PC Desktop
Random turning off/on while watching tv
sounds like it could be a power issue. is the powercord on the back of the tv detachable? make sure its plugged in tightly. also if using a surge protector reset surge protector. if not using a surge protector try a different outlet. also if gfci outlet (has reset button on outlet itself) try resetting the outlet by pushing the reset button
Apr 04, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Ihave a sony KP53S75 TV there was apower surge and now there is no picture. The red light blinks 4 times can anyone tell me about this?
Hi, if this TV was hit by the surge and it was protected by a surge protector, please follow this reset procedure.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the problem is still there and the light is still blinking 4 times, this means that the surge has destroyed the Vertical deflection component. in this case, it will have to be replaced.
please rate and have a great day.
Mar 25, 2009 | Sony KP-53S75 53" Rear Projection...
Compaq Desktop won't start after city wide power failure
Dear! format your system and istall drivers after individual reboot ..
by khalid (Kashmir)..
E-mail:-shahworld_2998@yahoo.co.in
May 05, 2008 | Compaq Presario S6300NX PC Desktop
Bad RCA 32 Tube TV
Bad IHVT ( HV transformer ) part # 257805 or ASTI 2078
......................................................T.
Dec 11, 2007 | RCA F32650 32" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
