Question about Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher
Dishwasher does not get dishes clean, especially on the top rack. what happens is it leaves a dirty film on everything that sometimes includes small particles. any suggestions? thanks.
  • Maytag Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms notSpinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Hello, Recently my dishwasher has been leaving particles of food residue in glasses or other glass items. This is a particular problem when using the top rack, but the problem sometimes is also on the...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jul 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
The top rack does not get clean. There is a dirty
Most likely the "food grinder" screen is clogged, which limits the flow throught the pump, leaving thehigher dishes unwashed. It's flaw inthe design of whirlpool/kitchenaides. Not only does the screen clog but the teeth on the "grinder" wear down, the girneder does no grinding, and the food particles build up onthe screen, clogging the water flow. Open up the collector, pul out he choer/grinder and clean the screen. Check the teeth on it and if worn, repalce the chopper/grinder. If it happens again , then the choper/grinder driving mechanism is basd -- replace the pump/motor assembly.
Feb 21, 2010 | KitchenAid 24 in. KUDU02FR Built-in...
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher Logo
127 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
