Question about Kitchen Ranges
Five-burner 90com gas cooktop - gas pressure on all burners appears to have gradually reduced to very, very low - smallest burner so low you can barely see the flame Technician charged us large bucks to pronounce that all the burner heads had become fouled and corroded and should be replaced - one look at any of the heads shows this is rubbish I've noticed that the cooktop has a regulator controlling supply to all burners. Is it possible that the setting of this has drifted and, if so, can it be adjusted and where do I find an actual St Geroge -savvy technician to make the adjustment?
  • Kitchen Ranges Master
  • 43,501 Answers
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Mar 27, 2011
Since it has turned cold my flame on cook stove has yellow flame
It may or may not be related to outdoor temperature but it appears that your burners don't have enough air. See if there is an air adjustor under the burner in the gas piping.
Oct 05, 2014 | Suburban Drop In Black CookTop Stove - 3...
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Front right burner only comes on with half of burner heating, the other half does not work.
Low gas pressure, suspect blocked gas jet , cleaning would probably cure this, if in doubt contact your local gas safe engineer
Jul 16, 2011 | Jenn-Air JED8430 Electric Cooktop
Gas igniters on all five burners keep sparking (JennAir CCG556B)
Try cleaning around all the ignitors at each burner. Look for build up of cleansing product and/or food. Sometimes all it takes is a good cleaning and removal of a buildup to solve this. Worth trying before replacing a bunch of parts!
K
Jul 30, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Two of five cooktop burners fail to light
you can try to scratch the area where it grounds to with a wire brush or screw driver this will help sometimes. sometimes when it archs down try tighten the screws to lift up the ignitors into the hole better. or if this doesn't work replace the ignitors.
Jun 07, 2009 | Jenn-Air JGC8536 Gas Cooktop
One burner on a 6-burner gas cooktop misbehaving
sounds like the air /gas mixture is off.look at where the burner meets the gas valve (the knob) under the grates and play with the adjuster turn it slowly while the burner is on and this will change the value of the air/gas mixture good luck
Jan 25, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
NOT WORKING BURNER ON MY VIKING 6 BURNER COOKTOP VGSU 36IN
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
Aug 18, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
