Question about Intermatic WH40 - Water Heater Time Switch - NEMA 1 Indoor Steel Case - DPS
How can I wire a WH40 timer to a tankless water heater with 2 9kw elements? 240v 75amp 18kw. I do have # 8 AVG wire and 2 double breakers 40amp each. Tank you
  • dpetroni2006 Mar 27, 2011
    I want to used for swimming pool. I want the timer to turn on power after pool pump start and turn power off before pool pump is off.
    Mr. rrreddd tank you for the efforts to make me understand how tankless heater work, but my tankless heater is home build and has no flow sensor, so when pool pump is ON water flow .ALL I want is to DELAY POWER to heater. Is there another way to do it? I repeat NO FLOW SENSOR. The components of the heater are: 2 9kw elements,2 TOP thermostat for electric heater and relief temperature-pressure valve installed ON HOT WATER LINE. TANK YOU.
    Sergeant:
    Novelist:
  • 185 Answers
I would use two 40amp contactors in series with the 2 pole breakers and then cycle them with the Time clock. The time clock can't handle the amperage but the contactors can. You can use 240 volts to power the time clock or 110 volts and then you will have to match the coil voltage of the contactor to the power you use for the time clock....... and cycle both contactors at the same time with the time clock......Hope this helps.
As always, if you are in doubt about what to do, the best advice anyone should give you is to call a licensed electrician or HVAC tech to advise what work is needed.
Before you do any work yourself,
on electrical circuits, equipment or appliances,
always use a test meter to ensure the circuit is, in fact, de-energized.
IF YOU ARE NOT ALREADY SURE YOU CAN DO THIS JOB
SAFELY AND COMPETENTLY
REFER THIS WORK TO QUALIFIED PROFESSIONALS.
Posted on Mar 27, 2011
    Scholar:
  • 130 Answers
You probably could but my question would be "why?" Water heater timers are made to turn power off to waterheaters during the times that we dont need hot water, like in the middle of the night or while you are at work. This keeps the hot water heater from working during those times and wasting energy (gas or electric). Tankless water heaters already have this builtin because they only work when you actuallty turn on the hot water. If the hot water faucet is not turned on, the tankless heater never comes on. It does not use a bit of energy until the hot water is actually turned on. So it will not be using energy during the night or while you are at work. So there really is no reason to do what you are thinking about unless you have another reason that I cant think of. Tankless heaters are great and this is why they save 60% of energy of conventional tank heaters.
  • 3 more comments
  • rrreddd Mar 27, 2011
    if you are going to do what you want to do you are going to have to use two timers, one for each of the 40 amp circuits and set them at the same times. However this is still unnecessary because the heater will still not turn on until water is flowing through it anyway.
    I want to used for swimming pool. I want the timer to turn power ON for heater after pool pump start. I want the timer to turn power OFF for heater before pool pump is OFF
    My idea make sense to you?
    no sir.. no offense but it doesnt. There is no point in it. I totally understand what you are trying to do, but there is really no reason to do it. If it was a conventional water heater than I would say "sure thats a great idea! that will save a lot of energy and money." But these tankless do not work the same way and your heater will never come on until there is water pumping through it. And when the pump is not pumping, the heater will not work. The heater turns on by a flow switch that senses the waterflow coming through the pipe, If water is not flowing, it is off. If water is flowing, it turns on. This w/h is already going to do what you are trying to make it do.
    ok, now I understand. If your water heater isnt controlled by a flow switch then you will have to use two timers, one for each 40 amp circuit as I stated earlier. There may be other ways to do this but they would be more costly and would require professional installation.
I have a craftsmaster electric hot water heater 40 gallon 2 elements and I want to know if I need double circuit breaker for it because I have hooked it up and it isnt getting hot
most water heater of that size is rated 240v, therefore it needs 2-pole. is it 240v rated? make sure you have a properly sized circuit breaker & matching conductors (wires) with the kw rating of the water heater
Oct 05, 2015 | Water Water Heaters
How many wires does it take to wire a bosch ae125 tankless water heater
You need three #8 wires for AE125. Two #8 wires for AE115.
1) Copy following link for wiring information:http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
2) The AE125 has 3 elements, and requires 3 wires.Each wire is sized #8 copper, and is connected to 40 amp breaker, up to 100 feet. Over 100 feet, use 50 amp breaker and #6 wire. Oversizing breaker and wire is smarted and more efficient than undersizing.
3) Often a separate subpanel is installed to provide 3 extra spaces.
http://waterheatertimer.org/images/Main-subpanel-Tankless-600.jpg
4) Makes sure main breaker panel can accept additional 120 amps of draw without overampping panel ... and starving other appliances of full power.... that will damage appliances, overheat motors, and damage main panel and overheat main breaker. You want to oversize, not undersize electric service when installing tankless electric, which is why I do not recommend tankless electric installation, including issues of costing more to operate, and expensive repairs, and general money risk-nuisance of owning tankless vrs tank-type heater.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#stress
Dec 06, 2012 | Bosch PowerStar AE125 AE125 Whole House...
I replaced all parts but water heated won't get hot
You have electric water heater.
You replaced elements and thermostats but heater still won't work.
And tank was completely full of water, and water was running out of a faucet before turning power ON.
If elements are not fully immersed in water, they will instantly burn out.
If upper element is burned out, then tank will have NO hot water.
If lower element is burned out, and upper element is not burned out, then tank will have some hot water.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-it-works.html
If elements did not burn out, then that leaves 1 main suspect: the electricity.
1) Push in ECO red reset button on upper thermostat. If ECO is tripped out, then heater will not work.
2) Click circuit breaker all the way one direction and then back the other direction to make sure breaker is latched.
3) If tank has 2 elements, then it is 240volt.
If 1 leg of 240Volt circuit is not working, then 240V appliance will not work.
240Volt circuit needs both hot wires to complete the circuit:
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#120-240
Buy cheap multimeter from Home Center and set dial to 240-250-277VAC
Tape tester leads to woods sticks to keep hands away from power.
Power is ON
Test across top 2 screws on upper element should show 220-240 volts.
If you have 240 at top two screws, then skip down to step 6.
If no reading across top two screws, then move to top of tank.
4) Open connection point where wire connects to heater.
Test across both insulated wires should get reading of 220-240 volts.
If no reading, move to circuit breaker box.
5) Mark water heater breaker.
Turn off all breakers except water heater breaker and main breaker. (and breaker to light fixture where box is located)
Do not hold or touch or lean against anything metal.
Stand on dry boards and wear dry clothes.
If main breaker is OFF, the big wires that connect to main breaker are still HOT.
Remove box cover.
240Volt breaker has 2 wires connected with screws.
Test across both screws for 240Volt.
See if wires are loose.
If there is no reading, then breaker is not working on one leg.
To double check, move water heater wires to another same-size 240V breaker and then put ear against water heater to listen for bubbly-fizzing sound.
6) If you are getting 240 to water heater, then wire inside tank could be loose.
Do 30 minute troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 09, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have replaced the bottom element,and now i have no hot water. I check with a meter and have power to the top element but not the bottom one.
First of all, you have 240V water heater because tank has two elements.
You have no hot water, and tank has power to upper element.
Lower element has no power.
Something doesn't sound right.
You're not testing correctly.
Before doing anything, test across top two screws of upper element for 240Volts.
This will eliminate electrical problem as suspect.
Breaker must deliver 120V on both legs to complete the 240V circuit.
Every single-phase household circuit takes 2 wires to complete the circuit.
With 120V you need 1 neutral wire and 1 hot wire to complete circuit.
With 240V you need 2 hot wires, one from each hot busbar, to complete circuit.
Your water heater can appear to have electricity if breaker is delivering power on one leg of the 240V circuit.
To check breaker for sure, move wires to another similar size breaker to see if water heater functions properly.
http://waterheatertimer.org/B220C.html
If 240V circuit is good, then next thing is take 30 minutes and do full test of water heater parts.
This will identify exact problem(s) without guessing.
Buy 5$ multimeter from Home Depot. Install battery.
When test calls for continuity, rotate dial to Ohms (upside down horseshoe is ohms).
When test calls for testing voltage, rotate dial to 240-250-277 VAC
Add a comment for more help.
Dec 28, 2010 | Rheem Water Heaters
No hot or warm water what is the voltage reading susposed to be on the heating elements? I have 122 volts on each terminal on both elements but no action, what am i doing wrong?
If water is totally cold, then upper element is not getting 240V. Since element tested for 120V, then that says upper element is burned out, upper thermostat is bad, or circuit breaker is bad.
Best thing is to buy multimeter and do 30 minute troubleshoot:
Also read information below for understanding how water heater works.
Testing elements for voltage can be misleading.
If water heater has 2 elements, then tank is 240Volts.
240V water heaters have 120V on each element at all times.
So elements have hot 120V power, but they are not turned on until the circuit is complete with 240V.
Open following links to read specifics about 120V and 240V
http://waterheatertimer.org/How-water-heater-thermostat-works.html
240V is made from two 120V Hot wires from breaker box.
Each 120V line from breaker is called a 'leg.'
So 240V circuit has two legs, and both legs need to be turned on to complete 240V circuit.
Water heater thermostats turn off only one leg.
The other leg is Hot all the time.
So when you test screws on an element, for example test between a screw and any bare metal part of tank, then the screw will always show 120V.
That is just one leg of the 240V circuit.
But the 240V circuit is not turned On until both legs are connected.
Every residential circuit needs two wires to complete the circuit, and in the case of 240V, those two wires are both 120V.
When the thermostat turns on, it turns on the second leg to the element and that completes the 240V circuit.
Dec 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I awoke to no hot water, my heater is three yrs old and i just changed my upper and lower element and upper thermostat, still no hot water then i checked to see if i was getting power and i am, is there...
Your water heater has 2 elements so its 240Volts.
1) If breaker is delivering power on one leg of the 240Volt circuit, then water heater can appear to have electricity, but tank is receiving 120V. Both 120Volt legs are needed to complete the 240V circuit. Double check for 240Volts.
2) Review electric Load.
Water heater label shows wattage of tank.
If tank is 4500Watts for example, you installed 3500 or 4500 watt elements.
With 5500 Watt elements you need 30 amp breaker and orange-colored 10 gauge wire
With 4500 Watt elements you can get by on 20 amp breaker and 12 gauge wire up to 75 feet away.
3) Check ECO red reset button on upper thermostat. If reset is tripped, then ECO is reading high temperatures. Suspects at this point are defective upper thermostat, shorted wire or bad lower element.
4) Also note that insulation and cover must be re-installed over thermostat. Thermostat reads temperature through wall of tank. If outside air circulates around thermostat, that can cause a mis-read and cause tank to overheat and ECO trips.
If you don't want to test the heater, replace both thermostats for about $25. Return the upper thermostat for a refund. Then see of problem persists.
Here's what I would do.
1. Check breaker for 240
2. Check water heater for 240 across 1 and 3 screws on upper thermostat
3. Note wiring and breaker size.
4. Note label on side of tank.
5. Look at end of new element to see wattage printed on each element. Look for sings of high heat and burning. Tighten screws on elements.
6. Check ECO reset button. Look for high-heat and burning. Tighten screws on thermostat.
7. Test upper thermostat as follows:
http://waterheatertimer.org/images/Electric-diagram-water-800.jpg
Test left-side #1 screw to right-side middle #4 screw. Test should read 240V at all times. If not, then ECO is tripped, thermostat is bad, or electricity is OFF
8) Water heater is cold so upper element should be ON. Test upper thermostat.
Test right-side #3 screw to left-side bottom #2 screw and it should read 240V
Test right-side #3 screw to right-side bottom #4 screw and it should read 0 volts
8. If upper thermostat checks out. Test upper element for 240 across both screws. If upper element does not read 240 when water is cold, then element is bad or there is a shorted wire between element and upper thermostat.
How to test element:
9. Do a full troubleshoot on electric water heater
Dec 07, 2010 | General Electric GE SmartWater Household...
I have an intermatic WH40 timer that works great when it is "On". However, once the unit encounters the "Off tripper", it turns the hot water power off, but the timer dial no longer...
If this is new installation, you have Load wires and Breaker wires reversed.
http://waterheatertimer.org/How-to-wire-WH40.html
http://waterheatertimer.org/images/WH40-water-heater-circuit-5.jpg
Hot wires from breaker connect to terminals 1 and 3 ... notice also there are small white wires connected to terminals 1 and 3.
Small white wires go to 240Volt clock motor located on back of mechanism, so these terminals have to be Hot all the time so clock motor is ON all the time >> thus hot wires from breaker connect to same terminals that have small white wires.
Load wires to water heater connect to terminals 2 and 4
Reverse your wires and things should work fine.
Dec 05, 2010 | Intermatic WH40 - Water Heater Time Switch...
Wiring a wh40 intermatic timer to a sears hot water heater
Shut off breaker to you water heater. STILL TEST FOR VOLTAGE BEFORE YOU TOUCH ANY WIRING. The 3 wire that go to you water heater disconnect them. You are going to install them to your WH 40 timer.
The wires that you disconnected will now go to terminals: Black to Terminal 1 & White To Terminal 3, The Ground copper wire will go to the ground terminal should be a green screw.
You will have to buy some 10/2 wiring to go from your timer to your water heater. You can buy it by the foot at Lowes. Figure how much you will need.
With the new 10/2 wire install the Black to terminal 2 & White To Terminal 4, the ground wire will go to the ground screw with the other ground wire.
Wiring that went to terminals 2 & 4 will be installed to you water heater, the same way when you disconnected them. Set your timer clock and your done. Turn breaker back on!
Dec 28, 2008 | Intermatic WH40 - Water Heater Time Switch...
Intermatic WH40 - Water Heater Time Switch - NEMA 1 Indoor Steel Case - DPS Logo
140 people viewed this question
Top Intermatic Water Heaters Experts
Steve
Gary Nitowski
ray gallant
Are you an Intermatic Water Heater Expert? Answer questions, earn points and help others
