Question about Ryobi Cultivator
Hi,I have a ryobi two cycle tiller,the gas line broke and after replacing the hose it will idle all day long but when i give it gas it dies.I know a little bit about air/gas mixture so when i put my finger over the carb hole it runs pretty good. I have tried about everything
SOURCE: Ryobi gas string trimmer won't run
I have a RYobi SS30 and it will not run at all. I have pulled the cord about a hundred times, yes after about 10 I should have gotten the picture, but if anyone knows what to do to correct this I would appreciate this. I am not very mechanically inclined so any help would be appreciated
Posted on Sep 28, 2008
  • 97 Answers
SOURCE: Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Posted on Mar 20, 2009
  • 45 Answers
SOURCE: Ryobi Model 65020 gas tiller dies when engaging the throttle
sounds like you need to adjust the carburator
Posted on Apr 29, 2009
panilling9
  • 284 Answers
SOURCE: when givin throttle dies
if they are not capped with limiter caps
you can try this turn both adj. cw with a small screwdriver until
they bottom out do not force once they stop turning
now back them out 1and1/4 to 1and1/2 ccw
that is the approx. initial setting.
Posted on May 31, 2009
TeleFurb
  • 16 Answers
SOURCE: ryobi weed eater ONLY RUNS WITH CHOKE ON HALF WAY
Check the carb jets, they might be a gummed up!
Posted on Aug 25, 2009
The tiller starts fine but then dies when you get it to full throttle
Did you put in new gas, and the proper gas oil mix for a 2 cycle, if required? Be sure your gas lines are not cracked or hard, this can cause leaks and hose breakdown, ie carburetor issues.
If so you should try putting in some Sea Foam gas additive. Most auto parts stores have it, it is great and has solved a lot problems for me with out tear down.. Let it run a while, at med or fast idle, then come back later or next day and try to run it, after a couple of running sessions mine straightened right out.Carburetor may be gummed with varnish, the sea foam seems to help reduce that and with running time, eliminates it.
Apr 14, 2012 | Honda Middle Tine Forward Rotating 9 In...
Mantis starts ok, and idles just fine, but when you give it gas it dies?
Start with the basics. Check condition of fuel lines and fuel filter. May need a simple adjustment by backing out on the low mixture screw just enough to give you a smooth "throttle up". You may also need to open the high mixture screw to obtain proper high speed. If adjustments do not correct the problem, you could be looking at overhauling or replacing the carburetor, whichever is more cost effective. Hope this helps.
Feb 24, 2011 | Mantis 2-Cycle Tiller
STARTS OK WITH PUMPING THE FUEL BULB AND CHOKING AFTER SEVERAL PULLS AN DRUNS IN IDLE BUT WHEN I TRY TO GIVE IT GAS IT DIES.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 06, 2010 | Mantis 2-Cycle Tiller
Ryobi blower stars and idles great. dies when you
Sounds like you need to clean the carb. Buy some carb cleaner and remove the lines to the carb and gently spray cleaner into each of the holes. Reconnect the lines.
Oct 24, 2009 | Garden
Ryobi 410r cultivator needs intital carb adjust ments,where do i start,how vmany turns on idle and high idle?
screw in lightly till seated then back out 1 turn each. low is for idling and turn in or out for best idle then run full throttle and do the same for it, get highest rpm then turn out 1/8 more on the high jet.
Jul 10, 2009 | Ryobi Cultivator
Apr 25, 2009 | Ryobi Cultivator
Replacing the 3 fuel lines
check my postings 3 days ago it give a good run down
Dec 20, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Ryobi Cultivator Logo
21 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
