Question about Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens
Nikon dx swm 18-55 mm
I can't rotate the zoom at all. in fact when I detached the lens I noticed that one of the parts (a small round part) was moving about in the lens. Any help?
  • 5 more comments
  • melinda1174 Aug 11, 2008
    Wow! I'm having the same exact problem! I can't zoom my lense. The shutter is slightly closed, almost wink-like & that little piece is loose inside at end that attaches to camera. Please help!
  • yazaq Oct 04, 2008
    Same problem here. I guess it started from the time that I dropped the camera. It was working for a while after that, with a little bit difficulty in rotating. But the problem started when I tried to focus on a small object, kinda macrophotography. Now, it's stuck. I can see a small plastic ring 15mm inside the lens, idly moving.
  • Anonymous Dec 13, 2008
    Same here :(, it's a black ring, inside that looks broken. A shady repair shop guy said there is no choice but to buy a new lense because repairing it would cost more than it's $150 value :(.
  • Anonymous Dec 20, 2008
    I have the same problem! Manufacture error perhaps??? Can anyone help?
  • Photoholic Dec 26, 2008
    Nikon needs to do something about this. Mine broke/got stuck on Christmas Eve of all nights! No back up, and it's hard to shoot kids around the tree with my 70-200 :(
    I "baby" my camera equipment and it has never been dropped or mishandled.
    I know it's one of their cheaper lenses, but one would hope you would get more than a year's use out of it.
    Nikon: Please take care of your problem! Tamron makes a nice lens that is a bit sharper, but not quite the reach of the 18-55.
  • steph31885 Dec 27, 2008
    same problem!!! any help???!!!
  • Anonymous Mar 16, 2009
    Exacly the same problem here, its horrible, the apurture is all the way stoped down as well.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
This is a very common problem. It sometimes happens without cause, sometimes by tightening or removing a filter. There are a couple of keys that keep the front lens from rotating while zooming that are very thin and easily bent. They have to be removed and straightened, and the rear piece you see floating has to be reinserted. It's about a $40 job and half-an-hour by a local independent repair shop. Expect to pay Nikon twice that.
Posted on Jan 04, 2009
Nikon 18-55mm lens will no longer zoom to 55mm.
there must be a problem with the lens ring which are fitted inside, occasionally it gets worn out because of improper handling . alignments may have caused you the problem. but once again you need a professional help because you wont get any elements or parts easily except from the company.this lens could also may have jammed due to any reasons, may be a foreign body or so and because the af is OK you are still getting a sharp image up to actual 45 mm which you think to be 55mm. If i were you then I would have inverted the lens and tapped gently and then check it once again or best goto Nikon service centers .
Feb 06, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My Nikon 18-55 mm lens turns easy when zooming in, but is stiff when zooming out. There is no roughness in the movement that would suggest dirt.
hi there,
the zoom-rubber might have been loosen, so it moved too easy while you use it
you can fix it by contacting nikon representative technical support
thanks
Dec 12, 2010 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
On a new Nikon 18-55mm AF-S DX Zoom - Nikkor f/3.5-5.6 lens and a Nikon 55-200 mm AF-S DX Zoom f/4.56 lens is VR also included and standard?
Nikon currently lists two 18-55 AF-S DX and two 55-200 AF-S DX lenses. One in each pair has vibration reduction, the other does not. The ones with VR in the name have it, otherwise it doesn't.
VR isn't exactly an option. If it wasn't built into the lens initially, you can't add it later. A lens either has it or it doesn't, though if a lens has VR it can be switched off.
Aug 30, 2010 | Nikon Cameras
Image is too dark nikkon swm vr ed
Having received no response in over a month, I assume this is no longer a problem.
Aug 06, 2010 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Using a Nikon D200 with a new 18-200mm lens. When
HI I AM SAGHA CAMERA REPAIRER FROM MUMBAI,FIRST READ YOUR LENS SPECIFICATION CAREFULLY IT SAYS 18-200/3.5-5.6 IT SHOULD BE READ AS AT 18 MM IT IS F3.5,THEN AT 200 MM IT WILL BE F5.6 THATS WHY IT MOVES APERTURE FROM 3.5 TO 5.6.IT IS QUITE NORMAL. REPLY ME IF YOU ARE SATISFIED WITH MY EXPLANATION.
Jul 30, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Small piece of clear white plastic lodged in the viewfinder
Check the mirror in the camera for any debris, or the lens. Sometimes a quick brush off works wonders!
Jun 11, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
How to zoom and take photos using nikon dx 40 slr camera with 18-55 mm lens
raju70us,
If you are new to DSLR camreras then this should work for you, you will have to rotate the ring on the lens, look through the viewfinder while trying it and you will notice the camera zooming in, the lens will be autofoucing as it is held on the subject in automatic mode. There are other settings you will like to try once you are used to the functions. That will come to you as you are developing your skills. Enjoy your new camera!
randy320sgi
Jan 07, 2009 | Cameras
18-55mm lens won't zoom
DON'T TRY TO FIX THIS YOURSELF! You will only add to the damage. If your lens is in warranty, contact Nikon for instructions to get it repaired. If it is out of warranty, I would either pay Nikon for the repair or take it to a camera repair man.
Dec 27, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Logo
2,051 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
