Question about Haier (HNSB02BB) (17 cu ft) Refrigerator
The refrigerator blew a fuse in a college dorm and have tried to plug it into other outlets that I know work and the fridge does not work. Is there a reset button or any other troubleshooting to get this to work?
  • 291 Answers
SOURCE: refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Posted on Apr 03, 2009
ehmbee
  • 9 Answers
SOURCE: Haier Dishwasher hdp18pa - Power reset
Are you blowing a fuse or throwing a breaker? Either way there is a chance that no outlet you have chosen to test with yet is on a circuit with sufficient amperage-I had this with a microwave I recently had installed. If you have the manual, check for requirements regarding amperage. You then need to be sure you are using an outlet with amperage comparable to the requirements-this is on your fuse or breaker. If your requirement is, say, 20 amps, a 15-amp or less breaker or fuse is going to fail. I had to go to a 'clean' circuit from my garage with nothing on it to find out I did not have enough amps in my circuit. My solution was a dedicated breaker. Another option is to use my second option (which I did not need), to plug it into a gas generator with sufficient wattage/amperage. This ensures nothing else is on the circuit.
Failing all that, it could be the power supply for the washer, a circuit board issue, etc. Don't mess around if you don't understand electricity, though-it's not worth frying yourself.
Finally, if it worked ok before and this has just begun to happen, I'd tend to think it's an issue with the washer itself. Hope this helps.
Posted on Jul 07, 2009
  • 401 Answers
SOURCE: Sanyo refrigerator not working
SOMETIMES THE THERMOSTAT STICKS TURN IT ON AND OFF A COUPLE OF TIMES YOU MAY UNSTICK IT OTHERWISE YOU NEED TO REPLACE IT
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Jan 13, 2010
muffteck
  • 202 Answers
SOURCE: no power to refrigerator
sounds like the relay at the compressor
Posted on Mar 29, 2010
TheMobilian
  • 8220 Answers
SOURCE: reset button?
FRENCH DOOR SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 16, 2010
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
Oct 12, 2017 | Kenmore Refrigerators
The other morning I woke up to a fridge with no power. I'm not sure if the problem is the fridge or my oulet. The only reason I do not know for sure is that I cannot get my fridge out of where it is. So I...
The plug will have to be gotten to in order to test the refrigerator properly. Do check the right ampage fuse is fitted 13A in the UK.
There is no reset button on your model.
Jan 12, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Refrigerator has lost power no eletric to inside light, not cooling not freezing
First , check if is power in the outlet where the fridge is plugged in by plugging something you know works (table light , radio,etc.) , if it doesn't work , means there's not power at the outlet what could be a trpped breaker , burnt fuse , burnt or loose wire at the outlet, or a bad outlet ; but if you got power in the outlet , probably the fridge cord or its plug are bad.
Oct 15, 2009 | Whirlpool Refrigerators
Fridge won't start up.
have you tried testing the plug. Has the fuse blown in it? try changing the plug to see, then if this doesn't work try a different power outlet.
Sep 07, 2009 | Haier HNSB02 Refrigerator With Ice Box
Samsung american style fridge freezer power loss after internal light blew
try to unplug for 2 min and plug back in to reset the unit otherwise sounds like you cooked a board
May 20, 2008 | Refrigerators
Commercial fridge is blowing the fuse in panel all of  a sudden. Nothing has changed. Is it the fridge or panel?
unit could be using more power then normal if it needs cleaned, next time it blows fuse find and outlet that is still working (and not overloaded with other products) plug refrig in that outlet with extention cord and see if it blows that fuse.
May 16, 2008 | Everest Refrigeration EMGR24 Commercial...
Refrigerator and freezer not cold
it could be your cold control stuck turn it on and tap it a few times
Dec 11, 2007 | Frigidaire FRT15G4B Top Freezer...
Haier (HNSB02BB) (17 cu ft) Refrigerator Logo
78 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
