Question about SanDisk Sansa e250 MP3 Player
Can`t get menu to come up when turned on mp3mp4 player
The computer sees it as a removable dish
  • 1 more comment
  • warren_nance Aug 04, 2008
    when it is not conected to the computer and on the menu well not be desplayed
    the mp3mp4 player will not bring up the menu to
    play vedio,musice or pix. when it is not on the computer and is turned on?
  • warren_nance Aug 05, 2008
    now computer won`t find it
  • SanDisk Master
  • 6,487 Answers
The Sansa sometimes corrupts files. It seems to be a persistent firmware bug.Put the Sansa in MSC mode.
Connect it to your computer then follow this:
In My Computer, see what the driveletter is E:Sansa 250.
Start/Run and type in chkdsk E:/f (or whatever the driveletter is). Windows will check the disk, fix bad files by deleting them and ask if you want to keep copies of the bad files. You don't need to and this may help on your problem but if still the same try to update the firmware of this player.
Hope that helps........
Posted on Aug 04, 2008
  • Mark Gil
    Mark Gil Aug 05, 2008
    If that's the case try connectiong your sansa on another usb port and check if the computer will find it, if still cannot find by your computer better connect this to another computer and check if it will be working fine on it...
    good luck........
    Brigadier General:
  • 6,966 Answers
Initially, it would seem that your Sansa e250 has somehow messed its firmware hence, the menu will not come on when powered up. The hardware part of the unit is still basically sound as evidenced by the computer being able to read it as a removable disk.
The Sandisk site offers downloadable utilities to restore the firmware, repair and for most other maintenance purposes.
For failing to load the menu or freezing on the Welcome screen, pls click here;
For a Sansa Firmware Updater, pls click here;
For all other, pls try here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Novelist:
    Scholar:
  • 125 Answers
I'm not familiar w/ the Sansa but I'll give it a try.
The SanDisk Sansa e200 is an MTP device but can be switched into UMS mode, meaning it can be used as a hard drive, which is a good thing for Mac users and those who prefer to drag and drop tracks. The only caveat here is that the expansion slot will not work when the unit is in MTP mode.
Hope this was of help.
  • 594 Answers
Yes the computer will see it as a removable disk due to the way it is formated that is normal......all you need to do is plug it in to your computer. click on the start menu,click on my computer,click on your device(removable disk) once you do that it will show you what is on your mp3 player you can move and delete files this way..... to add music all you need to do is right click on the file and go to (SEND TO) send the file to the romovable disk and it will put the file on your mp3 player.....
    Genius:
  • 1,847 Answers
Yes it will be shown as a removable disk,.
Remove close caption
The CC (closed caption) option is usually set (on or off) from your TV's menu screen. From your remote (or TV), select the Menu, then look for Settings, and when you see CC .... you can turn it off. If you provide the TV model, more specific instructions can be provided.
Mar 03, 2014 | Televison & Video
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with your MP4 player.
Restarting your PC resets non-functioning USB ports, which may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure you install them.
Try connecting your player to another PC to see if the new PC recognizes it.
If it does, chances are your computer does not support the hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to recognize it.
Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable to get it to work with your PC.
http://applestore.altervista.org/mp3mp4.pdf
Aug 25, 2013 | Intel Computers & Internet
Can't make the player turn on. What do I do?
First try and reset the player.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
If that does not work try this,
Remove the battery - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
STEP 1 - Connect the device to the computer
1. Remove the battery from the player's battery compartment.
2. Put the hold/lock switch to lock.
3. Plug in your device to the computer.
STEP 2 - Format the device
1. Double-click My Computer.
2. Right-click on the player, which might show up as a Removable Drive, select Format.
3. Click Start.
4. Click OK when a "Format Complete" dialog appears.
5. Click Close.
Nov 12, 2010 | SanDisk Sansa m240 MP3 Player
Activating a new Mp3 mp4 player
Most MP3Mp4 players turn themselves off. you must install the software before you connect the mp3mp4 to the computer. Hong Kong software may not work on North American Windows.
Mar 30, 2010 | Computers & Internet
I have a Sansa c200 that will not turn on, although the light ring is on. When I plug it into the usb port on my computer it does not recognize it either. Thanks!
First try and reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa c200 MP3 Player
My mp3 dosent want to turn on and its charged
Jan 30, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
MP3tech 4gb MP4 player user manual
sir you didn't put your mp4 brand here take alook of mp4 pdf i hope this may help you
Jul 03, 2009 | Audio Players & Recorders
Nextar mp3 won't turn on/won't let me access files
1. push down the button slider that you see on the side of the mp3 player labeled <mode>. that unlocks it.2. then plug it into the computer, select my computer from the start menu, and click removable disk drive (its usually labeled [E:].) 3. then delete what you need to by right clicking them and selecting delete.
Feb 15, 2009 | Nextar MA933A MP3 Player
No sound
go to you menu settings and be sure speakers are turned on and are not set to external,if this does'nt fix remove your dish input to see if you have noise comming through with no picture only snow, if yes the dish is the problem.
Sep 08, 2007 | RCA D52W19 52" Rear Projection Television
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
