Question about Microwave Ovens
The bake element is not heating up. The lights and broiler is working. Please advise.
  • Microwave Ovens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Mar 27, 2011
Kenmore oven C880 676239J2 is not heating up... is the only fuse the one located under the light on top of the control panel?
I doubt that fuse is used for the heating element. If you can unplug the element in the oven, an ohmmeter should show you if it has opened up (burned out) on you. Turn off the 220 breaker in the breaker box before doing this even though there should be no voltage with the controls turned off. (There usually will still be 110 to the top of the unit.)
Jun 05, 2017 | Kenmore Microwave Ovens
GE Spacesaver JVM1660WB turntable does not rotate?
My range works and oven lights? Does this mean that the problem is the Relay or the thermostat? The heating elements for the broiler/oven look fine and so do the connections?
Aug 16, 2013 | Amana Radarange Microwave Oven
While pre heating oven, heard a sort of explosion. The bake element was definitely broken. A new one was purchased, installed, but it does not heat up. The broiler also does not work, but stove top does....
i have seen elements short out and cause the main board to fail. if eeverything else works you know you have proper power , so i would say the board is bad
May 12, 2011 | Microwave Ovens
Pleb30s8ccc baking heating element does not work. I checked the voltage at the terminals and am not getting a reading while the broiler gets a reading. What do I do next?
You will have to trace the wires back from the terminals to the switch or thermostat where they come from. The heating element will have its own thermostat & this is the most probable cause for the power not reaching the element. It will then have to be replaced.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Mar 24, 2011 | Microwave Ovens
We turned on our oven last night and it heated up to 345, wanted to get to 400, then my wife saw smoke form the right hand front of the inside of the oven. I wanted to check the element, but can't figure...
I am assuming you are referring to a conventional stove. First shut off power to the stove at the breaker panel. (either a 40 or 50 amp breaker). Check to see if the elements come on before proceeding.
Slide out stove and unplug it. Look on the back. There will be a vertical piece of sheet metal with 1 to 3 screws or a large flat panel with several screws (1/4 Inch socket). Remove this panel to reveal the leads to the bake element.
remove the leads. Then remove the two screws inside the stove (1/4 inch socket) to remove element. The model and serial for the stove should be located by sliding the drawer out at the bottom of the stove on the left side.
You will need this number for the correct element. They run about 20 dollars typically. Hope this helps.
Feb 17, 2011 | Microwave Ovens
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
Microwave not heating
In all likelihood the Magnetron, or Power Diode has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 26, 2010 | GE Microwave Ovens
The bake function on the oven is not functioning the rotary dial adjusts the temp setting after the bake function is selected 350 temperature is selected and the temp flashes and stays at 100 without...
You probably have a bad bake element or control.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa (but in the oven section, not in the microwave section), and please include your brand name and the full model number from the tag in or on the unit, and your symptoms.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 11, 2009 | Roper Microwave Ovens
Wont heat
Hi!
Here are two instances when this happens---
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 05, 2009 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
