Question about Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2 cycle Gas Engine 18" Chain Saw
I have a TB4218cc and need to replace the starter housing assembly. This shows to be discontinued. Is there anyplace to get used replacement parts?
  • 710 Answers
the part number is MC-9228-MD0701 and they carry it at this website:
http://www.troybilt.com
Hope this helps
Handie Andie
Posted on Mar 27, 2011
  • Tim Bowman Sep 03, 2012
    That would be great if it wasn't discontinued!
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
Nov 10, 2014 | Garden
I need to know the location of a starter for a Chrysler lhs?
Melco starter being used with the 3.5L engine,and a Nippondenso for the 3.3L. Both follow the same step-by-step procedure. By inference it sounds like there is only one wrinkle in that the procedure is as follows:
Disconnect the battery (-) cable
Raise the vehicle
Do not remove the wiring from the starter at this time, first:
Remove three bolts attaching starter motor to engine
Remove the starter/starter solenoid as an assembly from the engine:
Position the assembly so as to gain access to the connectors
Remove the battery cable nut, field terminal nut, and push-on solenoid wire connector and the other wires
Remove the starter.
Installation is the reverse. Clean the cable and wire connectors before reassembly.
So other than that, neither the Chrysler nor the Haynes speak of any unusual steps in the process.
Let me know if you find otherwise so I can pass the info on to other owners, please.
I haven't done this one myself, so it is limited advice I can offer. The figures show there to be a "cover" mounted between the starter motor and the engine (it looks like a gasket) and the top bolt hole contains a "starter shield retention sleeve".
So you might want to familiarize yourself with those at the time you finally remove the motor so you don't loose track of those small parts.
On the Melco it shows that the starter solenoid can be replaced separately, but doesn't show that for the Nipppondenso.
Your Chrysler Lhs starter is the primary device that will get your ride going, initiating the operation of the power plant so you can go on your way. In case your Chrysler Lhs has hassle getting started, you probably need to swap out the old starter to restore ideal ignition performance.
You're likely never going anyplace if ever you cannot get your vehicle torun as the starter in your Chrysler Lhs is damaged. The most effective remedy when it comes to a broken starter is to get a replacement and subsequently install it. You're going to love superb ignition on your Chrysler Lhs because of a fresh alternate mounted. You can certainly purchase either new choices or choose to order remanufactured variants instead. A lot of Chrysler Lhs starters out there are offered in sets or are for sale separately. It is advisable to shop for direct-fit or OE replacement parts so you'll be able to install them with no problem.
To locate a Chrysler Lhs starter that's going to provide outstanding functionality for a while and would not ruin your funds, do not be reluctant to shop with us. We stock components coming from companies like Denso, AC Delco, and Motorcraft so you're certain to acquire parts that will not let you down. All you have to do to avail of reliable car parts is to look into the Parts Train catalog and search for the right item that satisfies your requirements.
Nov 22, 2011 | 1999 Chrysler LHS
Replace a starter on toyota camry 1999
According with the repairt guide, check this porocedure to REMOVAL & INSTALLATION
  1. Disconnect the cable from the negative terminal of the battery.
Fig. Exploded view of the starter motor mounting - 5S-FE engine shown, others similar (click image for zoom)
  1. On some early models with cruise control, you may have to remove the battery.
  2. Also on some models with cruise control, remove the actuator cover and disconnect the wiring harness. Remove the three bolts and then lift out the cruise control actuator. Remove the bracket from beneath the actuator and put aside.
  3. Peel the rubber boot away and remove the nut and disconnect the negative battery cable from the magnetic switch terminal on the starter. Disconnect the electrical connector also located on the magnetic switch.
  4. Support the starter by hand and remove the two mounting bolts.
  5. Remove the starter from the transaxle.
To install:
  1. Place the starter motor in the transaxle and support by hand.
  2. Install the two mounting bolts and tighten them to 29-31 ft. lbs. (39-42 Nm).
  3. Connect the connector to the magnetic switch. Place the battery cable on the switch terminal and install the nut. Tighten the nut and position the rubber boot over the cable.
  4. Using the ignition switch, "bump" the starter over a few times and check for proper operation.
SOLENOID OR RELAY REPLACEMENT
The starter solenoid (magnetic switch) is an integral part of the starter assembly.
  1. Remove the starter from the car. Remove the heat insulator from the starter assembly, if equipped.
  2. Disconnect the wire lead from the magnetic switch terminal.
  3. Remove the two long, through bolts holding the field frame to the magnetic switch. Pull out the field frame with the armature from the magnetic switch.
  4. On 1.0 kW starters, remove the felt seal. On 1.4 kW starters, remove the O-ring.
  5. To remove the starter housing from the magnetic switch assembly:
    1. On 1.0 kW starters, remove the two screws and the starter housing with the idler gear and clutch assembly.
    2. On 1.4 kW units, remove the two screws and the starter housing with the pinion gear, idler and clutch assembly.
To install:
  1. If necessary, install the gears and clutch assembly to the starter housing. Apply grease to the gear and clutch assemblies and:
    1. On 1.0 kW starters, place the clutch assembly, idler gear and bearing in the starter housing.
    2. On 1.4 kW starters, place the clutch assembly, idler gear, bearing and pinion gear in the starter housing.
  2. Insert the spring into the clutch shaft hole and place the starter housing onto the magnetic switch. Install the two screws.
  3. On 1.0 kW units, install the felt seal on the armature shaft. On 1.4 kW units, install the O-ring on the field frame.
  4. Install the field frame with the armature onto the magnetic switch assembly and install the two through bolts.
NOTE There is a protrusion or tab on each part; make sure you line them up correctly.
  1. Connect the wire to the terminal on the magnetic switch. Install the heat insulator, if equipped.
  2. Reinstall the starter on the vehicle. Check starter system for proper operation.
Hope this helps (remember to rating and leave a testimonial comment about this answer).
Oct 13, 2011 | 1999 Toyota Camry
Our exhaust fan is really noisy. Nutone QT 100N-B model. Where can we purchase a new one?
This model has been discontinued but replacement motor assemblies are available. There is no off the shelf model that will fit in the existing housing. If you do not want to replace the housing then the motor assembly is the way to go.
You ca purchase the replacement from either site below:
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
Jun 07, 2011 | Broan-NuTone QT100L Fan
Got power from starter switch to the solenoid but no power to the starter motor can anyone help.
Take a wire and jump the two posts on the solenoid or touch the two cables together. If your starter works, then you need a new solenoid. If you hold the starter button and tap on the starter with a plastic hammer and the starter works you need new starter brushes. Anything else wrong with the starter and you need to replace the starter assembly , the manufacturer does not make replacement parts for the starter.
Oct 16, 2010 | 1981 Yamaha XJ 650
How to remove the starter clutch housing (Original part number is 212131 in the Illustrated Parts List online at briggsandstratton.com.) from the vertical crankshaft of a Briggs and Stratton engine, Model...
Brace the mower blade against the housing of the mower with a block of wood, so that the blade cannot turn.
Using a Strapwrench, a chainwrench, or a pipewrench, secure the lowet part of the starter clutch assembly in the wernch and turn it counter clockwise, looking down at the top of the engine.
Aug 12, 2010 | Briggs & Stratton Garden
The starter housing assembly of my ryobi brush cutter is damaged
If your somewhat mechanically inclined, you should be able to. I would need your model # to quote you a price for this part. We are a warranty service center for Ryobi, Ridgid, milwaukee, Campbell hausfeld, etc. Email your model # to desertairrepair@aol.com. I'll send you the schematic for your trimmer.
Feb 02, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Starter cable housing assembly
you need the model type and code off the engine only in order to find that part. that is also a murrey
Oct 11, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Starter flywheel is not engaging motor
If you blew a fuse you could have a grounded wire someplace. Check the wiring on the solinoid, on the battery, on the lights and anyplace there could have been a bear spot rubbed. If the flywheel does not engage check the flywheel gear on the end of the started to see if it is chewed and worn. These can be replaced easily,
Apr 04, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2 cycle Gas Engine 18" Chain Saw Logo
657 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
