Hi I have a used Phillips DPTV335. Was working fine until yesterday. Now when I power it on it clicks like it is trying to start up but then there is no audio or video. Only a high pitched chirp every second or so continuously. I do not see any tubes lighting up inside but the power button is illuminated. Any ideas?
  • rkrauss624 Mar 27, 2011
    I have some skill for trouble shooting but wonder is it worth the effort to repair? How difficult is replacement of any of these parts?
  • 4,889 Answers
The high-pitched chrip that you have means you have a malfunctioning flyback transformer. I have seen this many times before. The part cannot be repaired and replacement is the only option. It costs about 50-75$ and should be handled only by a qualified technician as it is located in an extreme high voltage circuit - 30,000V. If you would like me to get you a list of techs in your area just let me know your zipcode.
Posted on Mar 27, 2011
  • 2,098 Answers
Hi rkrauss624,
High pitch noise is coming from the shorted parts in the power supply section or its load. This was commonly caused by shorted secondary voltage regulator transistor/IC(mounted in the heat sink) or the load. You must check each output voltages to locate where the fault came from to narrow the job. You need also a copy of service manual if you are going to fix it yourself. If you don't have necessary tools and test instrument and can't troubleshoot the symptom yourself I would advice you to look for an experienced technician to isolate the problem.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
  • Jdvillanueva
    Jdvillanueva Mar 27, 2011
    You are currently assisting with another expert. I'm here if you need my help...
2011 f150 want start just click has new battery worked fine yesterday today want start just click
Possible internal starter problem. Try tapping on starter motor while key is held in crank position. If vehicle starts, suspect a starter motor problem and replacement will be required
Feb 28, 2016 | Cars & Trucks
Flickering light and screen
The power supply may be failing.
Mar 19, 2014 | KDS Computers & Internet
Im looking for a projection alighment chip for 60pp9202/17f phillips
you will require two of the STK392-120 Convergence ICs and possibly the 6.8 ohm resistors. The Phillips DPTV305 - DPTV335 convergence repair kit available from www.tvrepairworld.com has the two ICs and the 12 resistors plus the CD with repair instructions.
Sep 25, 2011 | Philips 60PP9202 60" Rear Projection...
2nd time--i have a phillips projection tv, can't read all of mod. #5----63h/17.( measures 55 inches diag.) 2004 nov.,dptv335, 347h, e 10839 receiver, no man. 2nd owner. My problem is the tv has a double...
Thats caused by failed convergence ICs your model uses two STK392-120 ICs and 12 resistors 6.8 ohm 1watt. You can get the DPTV305-345 convergence repair kit which comes with instructions from www.tvrepairworld.com
Apr 01, 2010 | Televison & Video
55'' rear projection Phillips (dptv335) Red Tint in 4:3 area
Sounds like your fluid in the CRT's need replaced. I would recommend a servicer take care of that problem. The corrosion that ethylene glycol can do to components is vast if you spill it on any of the PC boards. ( You know it as Anti-freeze ). Play it safe---Make a Call.!
Jul 24, 2009 | Pioneer Televison & Video
Can not start my computer
Plug the unit directly to the ac outlet if it is plug into a surge protector. See if it boots. Did you shut it down yesterday or was it left running? Any bad weather last night? You could try another computer memory and see it is the memory. Not sure what it could be at this point. What type of system is it?
It could possibly be a bad power supply.
I hope this helps.
Feb 17, 2009 | Acer Aspire™ T180 PC Desktop
Phillips DPTV335 colors out of alignment
you need 2 Convergence ICs STK392-120 you can get them at this link and they provide free step by step instructions with free tech support so you can do the repairs yourself.
http://servicemanuals.vstore.ca/
Mar 16, 2008 | Philips 55PW9363 55" Rear Projection...
No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
Feb 19, 2008 | Panasonic PanaSync SL70 (White) 17" CRT...
Televison & Video Logo
Top Televison & Video Experts
