Question about Makita 5007MG Factory Reconditioned 7 14 Inch Magnesium Circular Saw
I was going to buy the makita 5007mga circular saw but some comments on amazon say the blade guard gets stuck while cutting. One comment is from Feb 12,2011 and he states the guard gets stuck while cutting 2x lumber at a 45 degree angle using 5007mg which I assume is the same saw with out the brake. Do you know if this is a issue with the saw? Thanks
4 Suggested Answers
outdoorsman5
  • 631 Answers
SOURCE: I cannot get a perfect 45 degree angle with my
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
Posted on Jul 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: The return spring for the blade guard on my Makita
there should be a hole in the housing towards the back of the saw, you can go to Makitatools.com and download a breakdown for this tool.
Posted on Feb 03, 2010
rowdy45176
  • 2176 Answers
SOURCE: need to know where to
if you give me your general area I will try and find a local dealer for you, you can also look in the yellow pages under tool repair for an authorized dealer, but it is faster online to find one. Or if you want you can go to Makitausa.com and they have a locator. Let me know if you need more help before voting please and thank you.
Posted on Feb 17, 2011
What is the spring for in the 2000w makita circular saw
Other than carbon brush springs, the only other spring that I know of on a circular saw is for the blade guard so that it will automatically return to cover the blade after you make the cut. There should be a hook or a bend in each end of the spring and each end has a certain spot where it hooks so that it pulls the blade guard back in place.
Jul 13, 2014 | Makita Saws
How to replace a makita circular saw guard
Simple, unpug tool. Remove blade and back flange. Remove circlip and lift off guard. Unclip spring. Re-fit new guard. Refit spring and circlip. Refit blade.
Aug 18, 2013 | Makita Saws
Makita service in toronto
That all depends on the types of cuts you're making. Check out the reviews on amazon.com for the various blades and what they're good for:
http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=circular%20saw%20blades
Aug 05, 2013 | Makita Saws
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
Cannot get saw blade off a makita 5090d saw.
Lift the guard and clamp the blade in a vice using a pair of soft jaws and then undo the bolt.
Jun 10, 2012 | Makita 5090d 96v Cordless Trim Circular...
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
SPRING LOCATION FOR BLADE GUARD
go to a store that sells the one you have and look at a new one . some wrap almost around the guard and some don't
May 01, 2010 | Makita 18V LXT Circular Saw
The return spring for the blade guard on my Makita 5630D cordless circular saw came off. It is attached to the blade guard, but I can't figure out where it attaches to the saw housing. Any hlep would be...
Feb 01, 2010 | Makita Saws
Makita 5007MG Factory Reconditioned 7 14 Inch Magnesium Circular Saw Logo
111 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
