Question about LG Refrigerators
LG-P197WVS: Hose from under frezeer door to water dispenser broken. CAn't find part number for this hose. How do you get the hose the new hose in. Can not get plastic mold off inside door. Does dispenser come out the front.
    Problem Solver:
  • 9 Answers
Ck with REPAIRCLINIC.com. repair help & parts
Posted on Mar 27, 2011
Hose from under frezeer door to water dispenser broken. CAn't find part number for this hose. How do you get the hose the new hose in. Does dispenser come out the front.
That could prove to be difficult. The doors are usually filled with polyurethane foam. And you may need to remove the inner liner to see if you can gain access to the tube. It is rar that the door dispenser will come out because of that foam. You can try. This hose is usually just a length of 5/16 plastic water hose available at a hardware store.
Apr 24, 2015 | Refrigerators
The water supply hose where it enters the door at the bottom has cracked and broken how do we replace the hose in the door
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
May 06, 2012 | Refrigerators
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
Water is leaking from the bottom in the front left side of side by side maytag. water line is ok not leaking. can't see where it is coming from.
the water for the dispenser (ice/water dispenser in the freezer door) comes from under the frige then up thru the bottom hinge of the freezer door .. it then goes inside the door up to the dispenser .. its a plastic hose and it has to twist near the hinge each time the door is opened .. thats where it usually breaks or develops a pin hole leak .. you can replace the whole hose or just the damaged section if that easier ... since the bottom freezer.hinge where that hose comes up thru, is at the position of your leak then i suspect thats your trouble ... ..also check the condensate pan to make sure its not full .. thats a flat pan under the fridge ..you can usually get acess to it by removing the front kick panel at the bottom of the frige .. if thats full then look for a door seal leak (damaged rubber seal) ... a broken seal or open door will allow moisture to condense inside the machine ..that runs down into the condensate pan where it normally evaporates .. but a problem (like open door) will fill it up to overflow in time ....
Aug 05, 2009 | Maytag Refrigerators
Kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Oct 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water gushes out dispenser
Something has gotten into the fill tube hose of the tub.  You will need to pull the drawer out and look down in the dispenser assembly to see if there is something blocking the hose.
Dec 30, 2007 | LG WM-2077C Front Load Washer
Samsungrs21dcns water dispenser problem
just below the doors of the frig is a kick plate. remove the kick plate. on the left youll see a water line that goes into the freezer door. there is a connection for that hose just under the freezer. disconect the hose the press the water dispenser. if water comes out of the hose then the water line is frozen inside the door. you can use a hair dryer to warm up the dispener area both from the front and from the back, inside the freezer, it will take about 30 min to defrost. but, if you get no water from that hose then you need a new water valve. more than likely its frozen in the door. thats common on ge models
Nov 26, 2007 | Whirlpool GS6NBEXR Side by Side...
Water leaking from dispenser into refigerator/French door bottom freezer
IT IS PROBERLY THE HOLDING TANK / TUBES LEAKING TAKE LOWER CRISPERS OUT AND CHECK THERE ITS BEHIND THEM
Aug 26, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
97 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
