My central heating is trying to start but wont fire up. It begins to run then clicks like ignition is trying then stops It is Omega ehe100
  • 43,501 Answers
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Posted on Mar 27, 2011
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
Dryer turns but no heat
There is a ceramic fuse that ignites the gas to create the heat . Need to check by removing the front bottom cover and observe the rednes of the fuse igniting along with a clicking noise for the beginning activation of it. Then try to turn on your dryer . You might need to replace it. ( no ignition, no fire, no heat) . Good luck
Nov 02, 2013 | Whirlpool Dryers
I have a Omega HE100 ducted heating unit. It has stopped working last night. In fact, when I switch it on, the responsed instantly but the flame couldn't be lighted up and it stopped after 10 seconds,...
Most of them are electronic systems I opened my he100 up and cleaned and adjusted the burners well used to take 10 resets before it would fire now fires up as soon as electronic ignition start every time total cost $0 and hour half work
Aug 13, 2011 | Heating & Cooling
Quits running after it starts to warm up under 1 mile
Try your ignition coil. That year model chevy has a dry running coil and it does not go out all at once. It will spark and run while cool but just as soon as the everything starts to heat up the resistance in the coil begins to build and it quits firing. After letting the vehicle set a little while and cool off it will fire off and run just fine untill it starts to heat up again.
Jul 20, 2009 | 1994 Chevrolet Suburban
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Central heat/air unit for home blows cold air
sounds like your drain is stop up in wich is filling your air swich up with water the causes a miss fire the indoor motor will run untill you turn it off when this happens
Jan 13, 2009 | Omega Trane Furnace Draft Inducer Blower...
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Omega Climate Systems HE60 ducted heating unit(external) starts up. After 15 secs there is a clicking sound , and it stops. Could it be the sensor ignition?
I have had exactly the same problem with my Omega HE60. I see this was posted a few years ago; did you end up solving it?
Aug 11, 2008 | Heating & Cooling
Heating & Cooling Logo
142 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
