Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
When i take the top of my reddy hearter off it will start right up . but when it is on it will not start>
    Scholar:
  • 72 Answers
Check the condition of the spark plug electrodes. if they are dirty or cabon fouled the exra air movement with the cover on prevents the fuel from ignition. Also check the air pressure setting for the pump go to
http://www.msservice.net/desa/reddy-low.html for service parts
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf for the service manual
My guess is the plug is dirty or air pressure is off causing the no ignition problem
Posted on Mar 27, 2011
  • 232 Answers
A worn nozzle creates a spray pattern, where a good nozzle creates a fog.With a coarse spray pattern poor combustion results in an off colorflame, . The photocelldoesn't like the color, sends a signal to the computer whichshuts everything down. That's the job of the electronics. On HSI ( hot surfaceignitor) heaters it is all about correct flame color , not just flame. The part where you write "If I remove the cover again it runsfine" is a symptom of a bad, worn, or restricted nozzle (generally).Remember- the ignitor only stays red for 5 seconds, then the flame keeps itselflit. The nozzle's pattern is a cone. Lift the lid & the pattern widens(aerodynamics) - replace the lid and the cone narrows & possibly distortsthen the flame goes out. This nozzle rule will only apply if everything is correct as far asfuel delivery applies. The pump pressure must be correct- not almost correct.Set the pressure with a low-pressure gauge that registers12-15 psi max. A gaugewith a higher scale just will not read close enough to satisfy the system. If the pressure is not correct, the aboverule will not apply. Instructionsfor setting the pressure can be viewed at http://reddyparts.com/pressure.htm. In addition, a fan can cause the same problem if damaged ormis-matched to your specific model. I must mention that any air leaks onthe pressure side (or vacuum leaks on the fuel line, for that matter) betweenthe pump and the nozzle will create a rich/lean mixture at the combustionchamber, creating an off-color flame.
How do i get the start button on my desktop
sorry but my deck tops do not have icons they have physical buttons on the bax to start them .
Oct 22, 2015 | HP Computers & Internet
Can't find setting on my hp.
If you have windows 7 the Control Panel is on the start menu.
Or you can right click on My Computer and select properties the click Control Panel at the top left.
Feb 03, 2012 | HP Computers & Internet
115,000 btu reddy heater, 5 hrs used in sprayfoam-grinding environment. stopped working. when plugged in, only hums for a few seconds, then stops. how can i fix that?
First, remove the top cover. Inspect for a varmint nest. If clear, manually spin the fan. If it does not you either have a broken rotor that is binding or you have a bad bearing.
If it spins freely, apply power- see if the motor runs with the top cover removed.
If YES, replace the top cover. Its possible that the top is binding the fan.
If NO, the start capacitor is defective. The cap on R115 is internal and is not servicable.
Reading material about a hummer
Nov 04, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
When trying to connect to the internet via cord, my laptop will say limited or no connectivity. I have restarted it and started all the applications that were disabled. i also have the wireless chip for...
On the right below task bar find network conection >>> open network conection
On Local Area Conection ( cord ) right click >> properties rolls down to Internet protocol (XP) or IPv4(WIN7) click properties >>> on general tab choose Obtain an IP address automatically >>> click OK >> OK
akee_akee@live.com
Aug 16, 2011 | Dell Latitude C610 Notebook
I need instructions on how to bypass a hearter core in a 98 grand am GT. 3.1L
Connect the hoses that go to the firewall-this will bypass the core until you can replace it and can be done with a 5/8" pipe and a couple of clanps.
Jan 24, 2011 | 1998 Pontiac Grand Am
Heater pulsates &will not completely start up.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 14, 2011 | Reddy Heater-40,000 BTU Kerosene w/T'stat
My reddy heater smokes and then shuts right when you plug it in , If you take off the top cover it will work
Look at the fuel coming out at the spark pug, if its a spray and not a fog try replacing the nozzel, for the R 55 they are less than $20.00 from Reddy parts.com
Dec 03, 2008 | Reddy Heater-30-55,000 BTU Variable
RM115 Reddy Heater forced air heater problem
air pressure should be no more than 3.5 psi. could be your pressure is too high and is blowing out the flame.
Dec 05, 2007 | Reddy R155D Utility Heater
Heating & Cooling Logo
74 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
