Question about E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
New power supply problem
I recently installed an new power supply on my emachines comp. and it powers up, but then turns off after about a minute. everything is hooked up, but I'm getting nothing on the monitor. Any ideas? i've installed a new bestec power supply to a emachines 2260 but when i powered on the pc only turns on the mother board but not the HDD what that happens if everything is connected correctly?
  • 34 Answers
One of the reasons that this could be is that the power supply doesn't have enough power to power everything. Trying exchanging it for another one that has more watts. If this is an exact replacement as far as the wattage goes, then your problem may lie else where, and you may want to take it to a reputable local computer repair shop for further inspection.
Posted on Feb 19, 2009
SOURCE:
Got a machine but it keeps switching off after few minutes could it be power switch on front if so where can i get one
It isnt the power switch, it's the power supply itself. You need to get a new one from bestbuy.com, Tigerdirect.com or Geeks.com.
Emachines are notorious for their bad power supplies, and they usually burn out the motherboard when they die. Stop pushing that button and get a new Power supply before your board messes up.
Aug 30, 2010 | E-Machines eMachines Desktop PC
Emachines T2891 Problem
Check output cables from your new power supply.
The connectors should be foolproof,but they might not be plugged in correctly.
Mar 06, 2010 | Computers & Internet
Comp. does'nt turn on. power is good
Your question fails to provide sufficient information.
.."doesn;t turn on power good...."
do any lights on the pc illuminate
was it working before, and did it close down correctly
has it possibly been hit by lightning
have you recently opened the case to install new hardware?
Possible causes of a failed power up.
dead power supply
a video card not seated in its slot correctly
dud motherboard
motherboard installed incorrectly
no Bios battery on motherboard
faulty wall switch
faulty power pack switch
no ram installed
and on and on
thanks for using FIXYA
Oct 10, 2009 | Intel Motherboard
Recently I switched from an XP operating system to a Vista. My new PC is an emachine. I am having trouble installing on new emachine. Perhaps the new connections are slightly different? I emachines didn't...
I have just bee to Driverguide and the Vista driver is not there. I have requested it for information purposes, but you should request it yourself, to be sure. If it turns up, I will check to see you have it. Ian.
Sep 18, 2009 | Office Equipment & Supplies
Emachine D2880 no power clarification
your getting power to your PSU, via the green light on your mobo.
verify the PSU has a green light(most emachines do)
it sort of sounds stupid but, check the connection of the cable coming from the front of the case(the wires that connect to the mobo to the power button on the outside of the case.
if all else fails, take the pc out of the case.. put all components on a static free bag and start to rebuild your PC(without a case)
...this will rule out a short on the PC case, and faulty wiring from the case...
pretty much sounds like you've been through almost every step except replacing the PSU(you just said you tested/but your getting power to the PSU)
hope some of this helped
Sep 04, 2009 | E-Machines eMachines Desktop PC
Not powering up .supply fine
remove your cmos / bios battery for 2 0r 3 minutes, reinsert it n turn on yor comp.
Apr 09, 2009 | E-Machines eMachines Desktop PC
T2085 will not turn on
it does sound like a power supply. you can pick one up for around 80 bucks retail. they aren't that hard to install. 2 plugs on the mobo and one for each drive you have installed. all you do is unscrew the current power supply (4 screws on the back), then unplug all wires connecting the power supply to the components. then take out the old power supply and work in reverse with the new power supply.
if the computer doesn't work after that, it is possible that you need a new mother board. in that case, personally i would return the power supply and start looking for another computer.
but hopefully it is just the power supply.
Agent 10708
May 29, 2008 | E-Machines eMachines Desktop PC
try to run it with out the memory and see if you have the right kind, put one stick in and try that, if still does not work, then you must have a short on the motherboard. I would replace that. most of the time the power box goes out it shorts the motherboard out too. if a green light is on, the power box is good and the motherboard is out. Farren
Dec 25, 2007 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Emachine 5260
Bad power supply will do this
Oct 20, 2007 | E-Machines eMachines Desktop PC
E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply Logo
153 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
