Question about Kustom KPC12M / Phonic MAX 1000 Spkr & Amp Package
I need replacement crossover because they got burn
  • Kustom Master
  • 5,603 Answers
The crossover in these is very simple and if it is burned, likely your speakers, maybe both, the woofer and tweeter have been damaged and need to be replaced. Test the speakers before changing the crossover. You MAY NOT notice the damage until you start driving the speakers again. The voice coil of the woofer is a common thing to fry, and while it may not open up, often it becomes unbonded to the coil form and rubs the magnet pole pieces. The tweeter/horn often wipes out the diaphram or blows the element open. Some of these are piezo horns and they can sometimes survive. These are rated at 100 Watts and if your amp can deliver over 50 watts you have to be careful to not put too much power into these. I have several of the Kustom 10 inch ones and several of the 15 inch ones... Also I have two 15 double stacks and they all seem to use the same crossover. Believe me, the crossover is far from what I would call "special" like the advertisements say. As an electrical engineer I was very disappointed. Anyway, test your speakers as they may be the worst of the problem.
Posted on Mar 27, 2011
I have 2 peavey sp2 bx well I was pushing them really hard and blew the black widows. Now I have got a replacement and hooked it up and still no sound out of them. I do have the horns working but they...
The lamp bulb fusing is just on the horns. Check the Black Widows individually with an ohm meter for continuity. If the speakers themselves test OK, you most likely blew the crossovers. Peavey service (877-732-8391) can rebuild most of therir crossovers in house and they generally are cheaper to fix than replace.
Nov 02, 2014 | Music
My crossover on Behringer speaker cab ba-115 (15" bass driver plus tweeter) is bad. Does anyone have the schematic before I tear it apart?
There is very little to an inspeaker crossover that could go bad unless it was SEVERELY overdriven. I recommend checking the speaker individually on a wire from a stereo or something powered to verify this. A crossover is nothing more than a capacitor (high cutoff) and an inductor.(low cutoff). The 600 watts rating of the cabinet is an RMS rating, meaning, .707 actual peak value free of distortion. This means that you can only drive it about 71% of that without distorting or damaging it. You said, "very little signal gets to the speaker", which sounds like "very low volume" meaning, magnet stuck, speaker not moving much, meaning warped voice coil. Check that the speaker will move back and forth with your hand freely without interference or scratchy noise. If it doesn't, the voice coil is warped and the speaker needs to be reconed or replaced.
Mar 12, 2013 | Music
The tweeters are not working
The crossover caps may have failed, or the tweeters themselves burned out. Using a small 1.5 volt cell touched across the tweeter leads should produce a sound. If not- they are burned out.
Apr 11, 2012 | Harman Kardon Harman JBL LSR2328P Pair of...
I have a pair of Behringer B1800x-pro subs that I am hoping to power with my EP4000. Would it be best to run one per channel or would it be better to run them in series with the amp bridged?
Run one per channel... DO NOT forget to use an electronic crossover feeding the amps as the speakers are rated only up to 300HZ so you need a low pass feeding these or you may burn them up. Some people are using the DriveRack crossover module for example to prevent sending highs to the subs and smoking them.
Sep 21, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
Phonic S715 "15" 2way
This speaker is not an active one. This means that it hasn't integrated amplifier, so you need an external one. The cable from the amplifier goes to the speaker. Remove the woofer in order to get access at the inner parts and check these points:
  • In case that there is a crossover present there must be a burned out coil or capacitance
  • In case the cable from the female jacks at the back panel goes direct to the woofer, there must be the woofer destroyed or the cable disconnected. Check the cables, it's less expensive than to replace the woofer.
Post me back if there is a crossover in use or it is direct connected and any other points of interest you came up, in order to guide you further.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 25, 2011 | Phonic S715 15 2Way PA Speaker
The amplifier keeps burning the tweeters in the speakers after replacement
Please check the wattage of the replaced speakers, now check the cross over in the speakers, if the capacitors are short the voltage might flow into the tweeter coils to burnt them out. Also you can try and reduce the high frequency and also see if the tweeters heat up . If so use high wattage super cooled tweeters.
Check finally for fault in the amplifier output- high voltage/current.
May 12, 2011 | Peavey Pv 2600 Power Amplifier
Behringer b415 horn stop working how and where i get replacement
First thing is to test the horn as the crossover circuit may be the problem. If you need the part(s) for the crossover you can get them via DIgiKey.com, however repalcing the horn driver you may have to go through FullCompass.com and if the part has to come from Behringer it takes months.
Mar 16, 2011 | Behringer B415dsp Eurolive 600watt 15 PA...
I would like to know I have 2 subwoofer with amp how can I connect it the best way thank you
first, you will need a passive crossover, i do not believe that the mono out of the mixer has a crossover., if the amp does not have a crossover. you could use the "mono" output, and split the signal, with an adapter, to both channels of the crossover, then run both of the low outs to the 2 channels of the amp. or, you could hook the crossover to the main laft and right outputs of the board. send the 2 low outs, left and right, to the subs' amp, and send the two high outs, left and right, to the main speakers' amp.
Nov 24, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Alesis Monitor One crossover assembly removal?
The question is WHY would you replace the crossover network?
They seldom go bad... Usually the speakers aree blown before the crossover fails.
Jan 29, 2010 | Alesis Music
Kustom KPC12M / Phonic MAX 1000 Spkr & Amp Package Logo
301 people viewed this question
Top Kustom Music Experts
Michial Gueffroy
Are you a Kustom Music Expert? Answer questions, earn points and help others
