I have a maytag 9000 series washer and during a cycle of washing it gave us an F22 fault. After pressing cancel it changed to an F21 fault. The door would not unlock. We were able to unplug the washer and get it to reset. It seemed to be working fine and started again normally. It then said sud and again stopped. The door will not unlock so that we can remove the clothes that are in it. I am unsure as to how to at least get the door to unlock or if it is an easy fix to get it working again.
jsrock516
  • 5911 Answers
SOURCE: whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: Goes through cycle but does not drain Has error codes of F-2 or F22 also maybe SUBS or SUDS
This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. Follow these steps:
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with a 2 x 4, it makes access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, open the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door latch to the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistent error is a failed door latch. If all these preliminary checks are unsuccessful, replace the door latch. Follow these steps:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
NOTE: Another method is to access behind the front panel from the top with the top panel removed. Either method works, but I have found that going through the front offers better access.
The "SUDS" or "SUD" error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Obstructions in the drain pump and/or drain lines can attribute to air getting trapped in the drain pump and cause the error code. Double check all electrical connections to the drain pump and Central Control Unit (CCU). You will need to remove the top panel of the washer to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, slide the panel back, then off. The CCU is located directly behind the wash tub in the center of the washer. The Drain Pump connector will be the 6th connector (facing from the front L to R) in the center of the CCU.
3. Check the Pressure Switch to ensure it is good. The Pressure Switch is located to the right of the CCU as you are looking from the front. It is a small cylindrical shaped device with a connector plug and an air hose attached. The switch can be checked at several water levels by removing the plug and taking resistance readings at the connector pins. Readings are as follows:
(Pins are numbered R to L facing the from the REAR)
Pins 1 to 2 (SUDS Detect) - 0 ohms
Pins 3 to 4 (Overflow) - 0 ohms
Pins 4 to 5 (L1) - 0 ohms
Pins 4 to 6 (Empty) - 0 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Testimonial: "Thank you"
jsrock516
  • 5911 Answers
SOURCE: mhwe300v starts flashing 'suds' or
"F21" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system. Most commonly, this is an indication something is lodged in the drain pump or the inlet line running from the wash tub to the inlet side of the pump. If you've already checked the drain pump reservoir, then make sure the inlet side of the pump is not obstructed. This does not have anything to do with the timer.
NOTE: The washer will not complete a wash cycle until the conditions causing the error are corrected. A "SUD" or "SD" (Suds lock) error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are very simple repairs that you can perform yourself without the assistance of a repairman.
If the wash tub is full of water, you may want to use a wet/dry shop vac to pull a vacuum on the drain line and drain the wash tub. This will minimize any potential mess you may have to clean up.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: The error codes are not listed in the owner's manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
NOTE: Later model Maytag washers are manufactured by Whirlpool, so these instructions do apply.
Posted on Oct 05, 2010
  • 170 Answers
SOURCE: my MAYTAG washer 9000 series
F 21 means slow drain if you can here the pump that means something pluging it. remove lower kick plate . the pump will be there remove cleanout counter clockwise turn .put back together.. hope this helps...good luck
Posted on Feb 01, 2011
TheMobilian
  • 8220 Answers
SOURCE: my washing machine is displaying the following
F-35: Analog switch/water level failure
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 17, 2011
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
MHW6000XW LIST OF ERROR CODES AND WHAT THEY MEAN
F20 water only problem insufficient water supply open both hot and cold unclog hoses
F21 Drain problem clogged,frozen kinked
SUD excess sud using non he detergent or to much detergent
F22 front door lock door not closed properly
For these select poepwer/cancel twice to cancel cycle
Other f codes select power/cancel twice select drain& spin if youhave excess water
Jul 10, 2015 | Maytag MHW6000XW - MaximaTM...
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
F-21 code several times. We clean the pump. Start again the rinse/drain and spin cicle, and now present sd code and later f-21 code. What we need to do.
Joe
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * EpicĀ® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
I keeg getting the dreaded F11 anf DL code!
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
478 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
