Question about Toshiba Satellite A75-S2131 Notebook
I am hooked up to a LAN right now. My wireless finds signals but won't give me the option to put in a password when I click on a secure connection. It tries to connect without it and then gives me an error saying I do not have a valid certificate to be on that wireless connection (the router). I tried updating driver but I have no disc anymore. This comp is from 2005 and I no longer have any discs for it. It was re-imaged about one month ago. it took a beating in Iraq and had to be wiped clean.
    Master:
  • Toshiba Master
  • 126 Answers
Posted on Jun 04, 2017
r0chelle
  • 51 Answers
SOURCE: Wireless Internet
Try the rest button should be on the back somewhere and start again to set a password for it. download more info on your router and how to log on to it, if all else fails ring your isp as they will help
Posted on Jul 30, 2008
mspcrepair
  • 169 Answers
SOURCE: Toshiba laptop running Vista loses connectivity
The problem is not Vista, the problem is the Netgear. I have seen this happen time and time again with both Netgear (primarily) and D-Link (often). That's why I *only* recommend Linksys.
Worst case - go buy one from Walmart (yes, they have 'em). Hook it up and see the difference. If, somehow, the problem persists, take it back, and you've lost nothing. But I'd bet (as they say down here in the South "dollars to doughnuts") that's your problem :)
Hope this helps - remember to rate :)
Posted on Oct 02, 2008
  • 55 Answers
SOURCE: Wireless not working
first check whether the wireless switch on ur laptop is turned ON orn't.it should be kept always on
Posted on Nov 22, 2008
leecom72
  • 4806 Answers
SOURCE: Wireless network adapter won't turn on
Hi there.
It sounds to me that the Atheros wireless card may have gone bad, in some cases this does happen.
Check in the bios to make sure that the wireless adapter is enabled, apart from that i cannot suggest anything else as you have just about troubleshot everything a PC technician would do before coming to the conclusion that its the hardware which is at fault.
If the machine is still under warranty then please take advantage of that, if not then a reputable PC repair shop will be able to fit a new card in the laptop and they will make sure it works before it comes back to you.
Good luck and thanks for using FixYa!!
Posted on May 22, 2009
  • 4044 Answers
SOURCE: Windows 7 Network Security Key Mismatch
The Key is Case sensitive. That is c is not the same as C. Before you enter the key activate your caps lock as most routers automatically translate letters to capital letters for some reason. It sounds as though the key is being entered incorrectly.
Posted on Jan 13, 2010
Dell vostro a860 won't connect to internet
Why not? Do you have the wireless turned on? Did you put the correct password in?
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the Authentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 28, 2012 | Dell Vostro A860 Notebook
Cannot establish connection with 2Wire and Netgear N900 wireless USB adapter WNDA4100
Why not, what type of message are you getting?
Let's start with Internet Options. If you have Windows XP Click Start/Control Panel/Internet Options. If you have Windows Vista or Windows 7 click Start/Control Panel/Network and Internet/Internet Options.
When the Internet Options window opens on the General Tab make sure you have a valid web address as the Home Page. If not, create a simple Home Page by typing: http://www.google.com You don't have to click OK now because if you do the Internet Options window will close.
Click the Security Tab and under where it says "select a zone to view or change settings" Click on the one that says Internet, then scroll down to near the bottom right and make sure that DEFAULT is grayed out (whereas you cannot click on it). You can Click on Default just to be sure. Next click the Intranet so that it is highlighted and make sure DEFAULT is grayed out so that you cannot click on it. Do the same thing for the other two zones (Trusted Sites and Restricted Sites). After all zones under the Security Tab are set to Default click the next Tab which is the Privacy tab.
On the Privacy Tab you want to make sure that DEFAULT is grayed out, if not click on it. When in doubt just click the Default tab.
Next skip over the Content tab and proceed to click the Connections Tab. On the Connections Tab make sure that the Never Dial A Connection is checked if you have something in the white box above it in for Dialup and Virtual Private Networks settings. Look down on the right near the bottom and Click the LAN SETTINGS button. When Lan Settings open up the only box that should be checked is the very first box that says: Automatically Detect Settings. If any other box is checked remove the check from it or you will never be able to connect. Click OK to close the LAN SETTINGS tab.
Next skip over the Programs tab and click the Advanced tab. When it opens slide the blue bar on the right all the way down until you get to the bottom of the window. You want to be able to make sure that if you see something like (Use SSL 2.0, Use SSL 3.0, Use TSL 1.0) that you put a check in the box to the left of each one of them. Afterwards you can click OK to close the Internet Options Window.
Authentication
May 27, 2012 | ASUS Computers & Internet
Need to lock and setup a password
Connect a computer to any one of the four LAN ports of the Netgear
Check the ip-address on the computer first,on the right side corner u have u will have two computer blinking double click on that (click support or detials )u will find ur Ip-address
or
wireless router. DO NOT use a wireless connection, use a cable.Open your web browser and type the IP address of the router (by
default, the address is http://192.168.1.1.) in the address bar and
press Enter.
It will ask u for a user name & password-admin - password
On the left side on top under set up will have option called wireless settingit will show u network name ,below security options change the security to wepon key 1-make ur password ( 10 numbers) & click apply
Then try to connect ur tablet to wireless it will work
kindly rate this post. thank you.
Jan 04, 2012 | NetGear WGR614 Wireless Router
I can't find my password on my netgear wnr 2000 router
or
press Enter.
On the left side on top under set up will have option called wireless settingit will show u network name ,below security options u will find ur password
Then try to connect ur wireless it will work
Jan 02, 2012 | NetGear WNR2000 Wireless Router
Can not access the internet with one of three laptops. Our technician said that we would need to use a login and password, however an option to use it never comes up? Have tried twice through Comcast...
>try to go to Control Panel
>click on Network and Sharing Center
>click on Manage Network Connections on the left side of the page (if there's no such option: click on Connect or Disconnect link on the upper right part of your Networks icon)
>it will give you the icons for LAN and Wireless Network Connection
>right click on Wireless Network Connection
>click on Connect or Disconnect / connect to a network / View available Networks 9 whatever option it givees you
>select your wireless network
>it will ask you for the Security Key or Passphrase ?
>commecnts, ratings, sugestions and violent reactions will be greatly appreciated
Sep 20, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys WRT160N Wireless Router
How configuring my netgear wgr614 v6 wireless router?
1. Connect the Netgear wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL ie. http://192.168.0.1
3. Enter the login and password - login = admin PW = password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further secutity measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. remove the LAN cable and the computers should be able to connect to the router.
11. Check the signal strength, if the signal is weak then move the wireless away from concrete walls and locate it higher.
Sep 27, 2009 | NetGear WGR614 Wireless Router
So i have my desktop set up online, but i want to get my laptop hooked up as well and i have a router. how do i hook that up to?
On the right bottom corner of your screen, you should see a message/icon about wireless networks.
Select the icon and you should see a list of wireless networks. Select your network, add your password (if you set up a password) and you should be connected.
Open your browser.
Hope this helps.
Sep 08, 2009 | NetGear WGR614 Wireless Router
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Jan 11, 2009 | Netopia Cayman 3347W-Ent Wireless Router
SECURITY BREECH,HOW CAN I CHANGE MY USER CODES?
I am not sure what you mean by User Codes. But you can try changing the SSID and secure it with a new password. Buy a broadband router that includes a built-in firewall, even if your broadband provider doesn't include one with the service package. Secure your wireless network with WPA or WEP. Turn your wireless off when you are not using it. This will prevent others from trying to use your wireless network. Try to check who is using your network and block him or her.
That is all the advice I can give you.
Good Luck.
Mar 01, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
