Question about Eliminator Pearl H2000 Powershifter Eliminator Hi Hat Stand
Bought used pearl double bass set for left handed player. How do you conver t r handed, NO diagranms with paperwork for assembly . Can I get detailed diagrams? dougzdrumz@hotmail.com 972 922 6539
    Problem Solver:
  • 11 Answers
Try looking it up online
Posted on Mar 27, 2011
No sound from hofner icon bass
there is a switch in the jack socket that lets it know jack is in use. when the stop working it usually means you need to change the jack, you cannot bend the part back with out breaking it so just best to change it. you can get a replacement jack from ebay, or any electrical supply shop that does small components.
Jul 02, 2017 | Hofner Icon Series Beatle Bass Guitar LEFT...
Im having problems attaching my Gibraltar Intruder Direct-Drive Double Bass Drum Pedal  to the bass drum
Does it hit the drumhead?
I guess you need to read the instruction manual, because double pedals usually have special way of attaching and tightening mechanism because it's larger.
Mar 03, 2014 | Gibraltar Intruder Direct Drive Double...
Put new string in a hohner steinberger bass very hard to turn tuner to pitch
You have stripped the threads on the string retainer part of the bridge adjusters. You will have to have it rethreaded with helicoils or buy a replacement which is $39
Nov 02, 2012 | Hohner B2AV-CRS Headless Left Handed 5...
Fender Deluxe Active Jazz Bass buzzing when i don't have my hands on the strings
Try reversing the wires in your input jack. Please repost results. Thanks!
Nov 12, 2011 | Fender Deluxe Active Jazz Bass Electric...
My speed cobra double pedal has alwyas been fine but i think i must of set it up wrong or maybe damaged it because now the slave pedal beater won't touch the bass drum head, it's like a couple of cm's...
There are MANY adjustments and some may have slipped. The clamp of the beater to the shaft would be the most suspect. At each of the universals there is the possibility for loose setscrews. Also see if the chain on the slave could have SLIPPED one cog !!!
Feb 27, 2011 | Tama HP910LWS Speed Cobra Double Bass Drum...
The Pearl BBC-1 bass drum masking plate does not fit the holes on my export bass drum
Your choices are few... get the correct plate, drill the one you have, or drill the drum.
I would opt to drill whichever part is the most replaceable which is likely the plate. Mark carefully an make sure it is square when you do so.
Feb 11, 2011 | Pearl Bass Drum Masking Plate BBC1
What potentiometer is being used in rbx 374 bass volume control..because i replaced it with a500 potentiometer but still its not working..i bought yhe bass second hand,,is potentiometers for active pickups...
Yes, active use different value pots than passive. The volume control is LIKELY an "audio taper" which can be either an "A" or a "B" marking as there is confusion about the marking. The resistance is likely around 500K ohms down to as low as 50K ohms. The marking MIGHT be something like 504 B or 503 B or the same with the letter "A".
An A500 pot might be only 50 ohms... That would result in very low output. Again, the marking in the industry is not consistent.
Best bet is to get the part from Yamaha. Go to Yamaha America "parts" dept in California. You can search the phone number with Google.
Oct 10, 2010 | Yamaha Rbx374 4String Electric Bass Guitar
My Bass Drum trigger just stopped working .
this is an easy problem to fix. The piezo piece on the inside of your bass drum trigger uses a double sided tape that is fixed to a metal disc. the piezo trigger just fell off. mine did the same thing. I actually glued mine with epoxy and have not looked back.
Nov 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Eliminator Pearl H2000 Powershifter Eliminator Hi Hat Stand Logo
57 people viewed this question
Top Eliminator Music Experts
Michial Gueffroy
Are you an Eliminator Music Expert? Answer questions, earn points and help others
