Question about Portability Ltd Cummins Onan P5500/P6500 Premium Portability Kit - 0541-1295
I HAVE NO SPARK NEW COIL NEW BOARD 12 VOLTS TO THE COIL WHEN TURNING OVER 6.5 ONAN RV GENNSET MODEL 6.5NHMFA26115C SERIAL # C943139772
74 bonniville only runs on left side,new boyer ignition, new coils 6 volt ,new wires new plugs...new gas and filter
Only one side of engine runs? Could be a head gasket problem on the right. It is a mechanical issue, not an electronic or electrical possibility as in newer cars. Do a compression test of the engine to see if the right side has compression failure from a bad head gasket.
A 1974 model would be a 12 volt system, not 6 volts. The last 6 volt systems were in the 1950's. If your coil is 12 volt and the left side runs and fires good, there is nothing wrong electrically. Check for spark on the right side, it should have spark on all cylinders if good spark on the left side. If no spark on the right side,. maybe a problem with the rotor or the distributor cap.
May 30, 2016 | Cars & Trucks
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
I have an onan marquis 5500 watt RV generator that runs fine ,but won't generate.
Call Onan and tell them the Inverter Board is bad. If you're not producing AC Power, have them send you a new board or warranty the entire genset. It's unusual for Onan products to go out like that, but not unlikely that this is the source of the problem.
Typically, the DC motor outputs at 12 volts, so the leads going in to the inverter are only going to be a ground and a positive lead. Should be very simple to replace. Worst case scenario is you can hook an external inverter up to the DC leads on the front of that generator. Might not get the full 5.5kw from the system, but you'll be able to produce some power.
Oct 16, 2013 | RTO Cummins Onan HomeSite Power 5500
Manuals for Onan 6.5NH-3CR/16004P RV generator
onan mcgraw RV model NH-3CR/1600HP, need to know how much oil,what weight of oil how much etc, the type of spark plug , oil filter, all the specs
Aug 04, 2010 | Garden
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
Just finished 12 volt conversion on 49 V8 flathead. Starter engages but engine won't start. Appears to be getting fuel.
You might not have spark as the 12 volts needs a ballast resistor or the points burn out preytty quick. 8 volts at the coil in run with the points open and 0 with the points clsed and battery voltage at the coil when cranking. coil wire near the intake manifold while cranking should jump at least 2 inches. Closed points should be 0 volts at the neg on the coil. pos and neg should be the same 12 volts with the points open. if not either the coil or the points are bad. The condenser can fail and no spark with all the rest right
Oct 12, 2009 | 1991 Plymouth Colt
Engine turns over but won't start 2001 Jeep Gr. Cherokee 6cyl
Start with the control module,I think it is located under coil on this model,You have checked the rotor to see if it is turning haven`t you?If it is not you may need a timing chain.
Aug 07, 2009 | 1983 Dodge Challenger
Portability Ltd Cummins Onan P5500/P6500 Premium Portability Kit - 0541-1295 Logo
46 people viewed this question
Top Portability Ltd Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Portability Ltd Electrical Supply Expert? Answer questions, earn points and help others
