Question about HP Photosmart 3310 All-In-One InkJet Printer
I have a HP Photosmart 3310 all in one printer that gives me the error message Oxc18a0101. I've tried the suggested method of repair found on the HP website and in that process, I never got the "insert cartridges" message on the screen. All it would show was "printer access door is open". Also got advive on opening the right side of the printer which would have been a real chore since it doesn't open to be put together where that would be possible. Any other idesa?
  • 30 Answers
If you have performed all the ts steps then there is not much steps to do.. what you can do is a reset on the printer by doing a simple step..
unplug the power chord from the back of the printer >> press the pound (#) and no 6 key together >> without releasing the button plug in the power chord...
the alignment will continue..
check if this works or not or else i m afraid that you need to replace the printer.
Posted on Mar 27, 2011
    Guru:
  • 89 Answers
POssible hardware issue already.
"printer access door is open". it means the sensor inside the printer that identifies if the access door of the printer is open is already damaged or stucked.
POssible resolution is to open the printer but like you say its really a core work already.If you are an HP customer,they have a loyalty program where you can upgrade that printer to a newer version and you are not going to pay the upgraded version to a retail price but you will be given a discounted price with extra promo they have exclusively for hp customer only
Hope I help you a bit.
You can also send me questions on my
personal email - christian4122@yahoo.com
Your's Truly,
Christian from HP
I have a HP Photosmart printer and keep geting an error message :Oxc18a0101. I've tried 2 suggested solutions already and it did not work. Help
To cure it:
Hit * and # at the same time on your printer
Enter code: 123
Hit Right Arrow
Go to System Configuration
Hit OK
OK again
and OK a third time
Unplug power from printer
Unplug power from wall
Wait 2 minutes
Replug the printer
It should boot fine and be able to print again.
Mar 26, 2011 | HP Photosmart 3310 All-In-One InkJet...
I have a HP photosmart 3310. I'm getting the error:Oxc18a0101 message. I've tried a couple of suggested solutions ut neither has worked. Help!
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone
Try this and it works
Regards,
Ron
Mar 26, 2011 | HP Photosmart 3310 Printer
My HP Photosmart 3310 keeps giving Paper jam message. It ejects the page when cancelled.I have cleaned rollers as suggested by HP. Sometimes when you request a photcopy it prints OK sometimes, so I do not...
I have had the same problem on and off for over a year. Recently it got so bad the printer would not print more than one sheet without going into "Paper Jam" mode with no actual apparent paper jam. I found this video ( http://www.youtube.com/watch?v=Qs-Lyw5xXLg ) on YouTube explaining what to do for a similar model to the 3310. The video is very professionally done and was very thorough. I checked all the areas the video suggests and found that my problem was a tiny scrap of paper that was stuck to the right of where the printer carriage parks. 3310 works like a champ once again (still an ink hog though :(
Check out the video & good luck!
Nov 23, 2010 | HP Photosmart 3310 Printer
I have a hp c7280 printer with a error code OXC18A0101 what does it means
The "Oxc18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Jul 17, 2010 | HP Photosmart 3310 Printer
Error code Oxc18a0101 What can I do when this message appear???
From HP the rep said its due to air bubbles getting into the cartridge.
To cure it:
Enter code: 123
Hit Right Arrow
Hit OK
OK again
and OK a third time
Wait 2 minutes
Replug the printer
I Hope this will steps will fix your problem.
Jan 13, 2010 | HP Photosmart 3310 Printer
Printing error oxc18a0101
Try resetting the printer:
7- Plug in power source and turn printer on.
Jul 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Photosmart 8180 has error message Oxc18a0101
try to follow this instructions to fix the error: Hit * and # at the same time on your printer, then enter code: 123 press right arrow, then go to system configuration and press ok 3x. unplug power from printer and wait 2 minutes, plug the printer again and then it will all be back to normal. hope this helps. Good Day!
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error message shows up on printer screen oxc18a0101
Found this link that tells you how to reset the printer.
http://www.fixyourownprinter.com/forums/printer/39471
Excerpt on resetting the printer from the post linked to above:
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on.
Apr 05, 2009 | HP Photosmart 3310 All-In-One InkJet...
HP Photosmart 3310 All-In-One InkJet Printer Logo
103 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
