Question about Panasonic PT-47XD64 47" Rear Projection HDTV
Watching tv boom convergence shift ,can not adjust intial setting to horizontal center
  • Panasonic Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
e87380c.jpgSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture owatching tv boom convergence shift - 578ba6c.jpgt needs the fluid changed.
TV set after fluiwatching tv boom convergence shift - 69189a5.png />
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 15, 2011
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Tip
    How to set convergence on Projection TV ' s
    I have given an general explanation on most projection TV ' s
    1. Enter the menu on your TV. Use the remote control and bring up the menu.
    2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    4. Press "Enter." A crosshair pattern will appear on your screen.
    5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    8. Repeat these steps for all colors.
    on Mar 18, 2010 | Televison & Video
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    How do you set convergence
    What is your Make and Model number?
    Viewing mode will only go from zoom to wide!!!! please help
    Hi!
    Found some relevant info on how to adjust your video settings... You might want to give it a try!
    Thanks! =)
    4.12 PC Input Picture Adjustment
    The Picture Adjust menu operates in the same
    way for the PC Input as for the DTV / TV input in
    section 4.2 for Backlight, Contrast, Brightness and
    Color Temperature.
    4.12.1 Auto Adjust
    When the MENU button is pressed, the On Screen
    Display (OSD) appears on the PICTURE ADJUST
    page. Press the button to highlight the Auto
    Adjust selection.
    Press the button for the LCD HDTV to adjust to
    the PC signal timing automatically.
    4.12.2 H-SIZE
    Press the button to highlight the H-Size selection.
    Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
    the horizontal size.
    4.12.3 Horizontal Shift
    Press the button to highlight the Horizontal Shift selection.
    Press the button to start adjusting the horizontal position of the picture. Use the or button to
    adjust the horizontal position.
    4.12.4 Vertical Shift
    Press the button to highlight the Vertical Shift selection.
    Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
    the vertical position.
    4.12.5 Fine Tune
    Press the button to highlight the Fine Tune selection.
    Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
    4.14.1 Understanding Viewing Features
    Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
    You can switch viewing modes using the remote control.
    4.14.2 Viewing Modes
    Normal Mode
    The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
    added to the left and right of the display image. Standard TV broadcasts are
    displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
    to as pan-and-scan or full frame. These movies were originally filmed in 16:9
    (widescreen), and then modified to fit a traditional TV screen (4:3).
    Wide Mode
    When watching a standard broadcast or full-frame movie in this mode,
    the display image is stretched proportionately to fill the TV screen.
    When watching a widescreen (1.78:1 source) program or movie, the
    display image fills the TV screen. If you are watching a widescreen
    (1.85:1 or 2.35:1 source) program or movie, there will still be black
    bars at the top and bottom.
    Zoom Mode
    When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
    program or movie, the display image is zoomed proportionally to fill the
    width of the screen. The top and bottom are cut off to remove most of
    the source material’s black bars. This mode is good for programs or
    movies with sub-titles.
    Panoramic Mode
    When watching a standard broadcast or full frame movie in this mode,
    the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
    horizontally on the left and right sides to fill the TV screen. The center
    of the image is not stretched.
    Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
    mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
    will return to widescreen.
    Jan 04, 2009 | Televison & Video
    PICTURE HAS DISTORTED HORIZONTAL LINE IN CENTER OF SCREEN.
    Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
    • Screen looks 3D
    • TV shuts off after powering on - TV may also make a chirping noise.
    Here are some photos of convergence problems.
    Here is a quick test....
    Using your original remote go-to the settings menu then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move RED and BLUE in all directions - up, down, left, and right.
    If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
    Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
    93a1209.pngCONVERGENCE SOLUTION
    You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
    This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
    Jan 03, 2009 | Toshiba 55H70 55" Rear Projection...
    Hitachi 51SWX20B Convergence problem
    Solution:
    Your TV has a convergence problem. Here are some of the most common symptoms.
    Screen looks 3D
    Screen is bowed in or warped.
    Using your original remote go-to the tv settings then goto the convergence or magic focus section.
    Try to adjust the convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Its a fairly easy fix on the Hitachi sets.
    You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
    Everything you need to fix it yourself.
    Jan 28, 2008 | Hitachi 51SWX20B 51" Rear Projection...
    Can't watch footbal
    NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
    1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
    Dec 16, 2007 | Philips Televison & Video
    Center screen convergence problem
    The convergence adjustment on the TV set are for the center adjustments ONLY. if you cannot get them in or they are way out, then you have a convergence IC problem. Dont feel bad though as it happens to every rear projection set ever made. Good Luck
    Dec 30, 2006 | Toshiba 53AX62 53 in. Rear Projection...
    Panasonic PT-47XD64 47" Rear Projection HDTV Logo
    23 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
