Question about GE Kitchen Ranges
I have a GE GSS25QGTA WW side by side SN FM307395 It started to make strange noise. We have had it about 3 years I guess and It is a new noise. The noise is coming from the freezer. I checked to make sure it was not to full and the vent at the back bottom was not blocked. I can here the fan in the back of the freezer surging. You can feel the air speeding up and slowing down coming out of the airvent behind the ice maker. You can also here a sound like water in pipes thanks
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Posted on Mar 27, 2011
Model #rb215lash
I know nothing about your model, but in my experience with refrigerators over the last 40 years, they can make a whole range of different noises at different times. There's even a note in the manual of my GE side by side something to the effect that strange noises are to be expected. I'm amazed at the range of different sounds that comes from our 10 year old GE. It's hard to say ignore noises because I never ignore a new noise from my car, but unless the same noise repeats under similar conditions, I'd not rush into trying to 'fix; it.
Apr 14, 2014 | Samsung Refrigerators
We have a GE gss25qgta ww and the ice cubes won't dispense but the water is working. There also seems to be frost building up on the coil in the ice tray. There is also occasional noise - sometimes quite...
Here's what I found for you.....
go to this site....
http://www.appliancepartspros.com/repair-help/general-electric-refrigerator-gss25qgtaww-repair/gss25qgtaww-ice-maker-wont-dispense-ice.html
the part is 32 bucks and if you are able to follow the video repair you can do it yourself. two things needed a putty knife and a phillips screwdriver. Probably a 45 min fix.
they have a 800# to confirm DIY repair. and insure the part is a exact replacement, or just to confirm the issue.
repair trip charge and labor could easily exceed the part $ x 3 to 4 times.
Hope this helps
Cheers
Feb 08, 2018 | Refrigerators
Need instructions on how to set the temp for a gss25qgta-ww refrigerator. Is there an instruction booklet or schematic online?
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60407-1.pdf
Jun 09, 2011 | GE Refrigerators
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan motor making noise
HI thanks for your question. the fan is located behind the freezer wall. 4or5 screws. remove panel. replace fan motor. thanks the appliance doc. please rate my answer. thanks
Oct 09, 2008 | Refrigerators
Ice Maker
Put less water into the ice tray.
Sep 23, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Loose door handle
If a tight place is worn out, then try warmer temperature and go to the tools store to place the door with your new tools.
Aug 08, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Kitchen Ranges Logo
319 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
