Question about Philips Magnavox 27MS343S 27" TV
How to set the telelvision to use a dvd,
It was working and set by my Cable tech, but Iran the auto programming and lost the ability to see the picutrue I have sound from the DVD but no picture philips maganvox tv. new philips dvd player. tv was given to me. do not know which station to use for watching dvd. scanned all channels. use chan 3 for cable. all wires hooked-up correctly according to directions. i think problem is tv--just need to know how to "adjust" to watch dvd player. any ideas.
thanks!!!!
  • 138 Answers
On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
Posted on Aug 19, 2008
Emotion tv
You will need three things to get this to start working again.
1. the original remote control that came with your TV.
2. the operating manual that original came with your TV.
3. and the ability to read the operating manual and follow the instructions on setting up the tv channels auto scan.
Oct 29, 2013 | Televison & Video
Lost channels how do i restor
Try to program with the remote first=in menu selected auto program-also if a box for cable/sat is in line consider it may be damaged.
A simple test is to see if a DVD etc works at all on set---try to see what is and what is not working one at a time.
Apr 27, 2012 | Olevia LT26HVX 26 in. LCD Television
Lost vaio tv listing
please do check the settings of the gigapocket for the mean time and i'll try to do something to help you out.
May 12, 2010 | Sony VAIO Digital Studio PCV-RX540 PC...
Cable channels wont program above 27 w my basic cable
Hi classmom2,
I will be happy to help.
You have probably tried this but I will go over it anyway. If it dosn't work we will try something else.
From the video menu on the tv, select the tuning band of CABLE not AIR. Then do a Auto-Channel Search.
From what I gather you have basic cable without a cable box correct?
Let me know what you find and we will go from there.
Lone99star
Jan 24, 2009 | Sharp LC-26D7U 26 in. HDTV LCD Television
How can I order the optical lens?
Hello Nader,
Are you in usa or iran?
Let me know to guide you further as I'm in service business with Aiwa in Pakistan.
Thank you.
Oct 27, 2008 | Aiwa XR-DV700 System
Channel stuck and can't record shows the same night
Your two problems are related - the DVD player lost contact with the local PBS channel, which altered its internal clock.
Add a red, white and yellow cable from one of the outs on the back of the cable box to the slot marked AV1 IN on the back of the Philips. Then redo the channel programming - press the System Menu button and change Tuning Band to CATV - it will then ask you if you want to do an Auto Channel Set - say Yes.
Once it is done with the channel programming, turn the DVD player to whatever channel PBS is on in your area's cable service. Then go back to System Menu - select Clock Set and go to Auto. Alternatively, you can select Manual under Clock Set and change the date by hand).
-Tha Mp3 Doctor
Sep 24, 2008 | Philips DVDR3320 DVD Recorder/VCR
Unable to get cable channel programmed into set
Access the customer menu, select cable vs. ant then go to auto programming and let it do it's magic.
Bill
Apr 23, 2008 | Mitsubishi WS-55807 TV
when you ran the autoprogramming it scanned all the channels you are receiving.the dvd is probably plugged into a line or aux input on back of your tv.look for a input or source button on the remote. some tv's have more then 1 input source so be sure to scan thru all input choices.also if it is a dvd/vcr combo & if there is a coax out connection to your tv coax/rf input the tv and/or cable box should be on channel 3
hope this helps
w.g
Jan 28, 2008 | Philips 19PR19 19" TV
Can't get any channels on the air.\
If the tuner is the problem then it is a very bad problem as the tuner is part of the DM module and that is very expensive. When you say you have to manually key in the channels, do they work then? If so the problem is not the tuner. If your only problem is that you cannot go from one channel to the other by using the channel up and down button on the remote, then you have most likely just lost the programming on the tv. Go into menu and set up and find the auto channel programming and run auto program to correct the problem.
Apr 28, 2007 | RCA HD50LPW42 50" Rear Projection HDTV
Philips Magnavox 27MS343S 27" TV Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
