Question about TDK MOJO 128F 128 MB MP3 Player
If you have the original TDK Mojo 128/256 Unifi software, I would very much appreciate it. I have looked everywhere for it on the Internet and the only thing I could find was a driver update, drvupd2100.exe, which is useless without the original driver already installed. Thanks.
Why does my Unifi projector goes off after a few minutes
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Sep 27, 2014 | Battery Technology Premier Projector Lamp...
I do not have acces to 192.168.1.20
Hello you may have to set it up again.
You can find info here:
http://www.ubnt.com/download#UniFi:AP
Try also to find the manual.
Good luck
Nov 14, 2012 | Ubiquiti UniFi Outdoor AP Single Unit
Where would I be able to download a driver for my TDK mp3 player?
http://www.lostmydrivers.com/driver/download/2232/TDK/Cameras-and-MP3-Player-Drivers/tdk-mojo-128f-256f-mp3-fm-player-mojo-software---driver-upgrade. hope this helps
Nov 27, 2010 | TDK MOJO 128F 128 MB MP3 Player
TDK Life on Record 1-16x speed DVD-R keeps failing when writing. I have burned about 25 dvds from this TDK pack, and all burn normally right up to near the end when my Nero burner software notifies "Burn...
You could try diferent burning software.it may even be a hardware fault the dvdr drive.cds and dvds burn and read data from inside to outer edge.as the laser moves out twards edge the speed of disc changes to compensate for larger distance travelled so a worn drive can sometimes start to show this fault.also sometimes only play half a film or stop at track 10 on cd
Apr 19, 2017 | Computers & Internet
I have a Tdk burner worked fine until my husband had his buddy install some other burning software now my burner doesn't read there's a cd in it and it keeps opening up...still looking for original tdk...
Installing different burning software should not really affect reading capabilities of the burner. Nevertheless, it is not recommended to have two burning software packages on the same computer.
You can try uninstalling the new software that was installed on your computer, the reboot the system and check if that worked. If Windows does not open the disc automatically, you can go to My Computer and access the disc by double clicking on the TDK drive.
If you continue to have the same problems, please make sure the DVD burner is connected properly to the computer.
Aug 21, 2010 | TDK (aid+420blkb) Burner
Mp3 player software freezes on my Vista computer
hi sir
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
May 24, 2009 | TDK MOJO 256F 256 MB MP3 Player
Screen displays..(internal media as...)
Dude, remove the batery, then, connect your mp3 in your computer, select in Windows menu: Format...but format in FAT...not in FAT32..or Ntfs...then, disconnect and connect again...put music...and thats it...¡¡¡ enjoy again...
Bye..
Oct 14, 2006 | TDK MOJO X 128 MB MP3 Player
TDK MOJO 128F 128 MB MP3 Player Logo
89 people viewed this question
Top TDK Audio Players & Recorders Experts
steve
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
