Question about HP PSC 1210 All-In-One InkJet Printer
Won't feed paper
The paper won't feed then message says out of paper but it'ts not
  • jersey3779 Aug 23, 2008
    no matter what i do, it won't feed. if i push the paper in farther, it will feed the whole bunch.
    Novelist:
  • 180 Answers
Open the back of the printer and then clean the rollers at the back. After that unplug the power cord at the back of the printer while it is still on. Then try to print after that. If it will still that it is out of paper then the sensor of the printer is already damage. You could either service the printer or replace it with a new one.
Posted on Aug 04, 2008
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
Hp Photosmart c4750 all-in-one printer; paper won't feed, with the power on and everything.
Check where you feed the paper you could have something in the way i remember one time i had a ecig charger stuck in mine it did the same thing more than likely something fell in there.
Oct 20, 2017 | Office Equipment & Supplies
Error message 3
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer connects to the PC.
(4) ***
5) Now, reconnect the USB/Serial cable and switch ON the PC (only PC and not the printer).
6) Let the PC boot up and login to windows.
7) Now, switch on the printer, PC should detect the printer automatically now.
Dec 05, 2011 | Office Equipment & Supplies
I have been using my shredder heavily in the last 30 minutes. I have had to stop twice for it to cool down. It was working fine, and now it won't accept paper. The cutters are turning fine. It is not...
Most shredders don't recommend use for more than 20-25 sheets in a session. Try using the reverse setting; even though you can't see paper, it's possible that there's some still in the feed channel. If after switching to reverse paper comes out, inspect the feed channel for more paper and clear any you find before trying to feed more sheets. Also in the future, constant use as you've described will burn out the motor.
Nov 16, 2009 | Tech Solution TS-4500 Shredder
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Power light blinking but cannot switch on
Usuall the power light will blink if the paper fails to feed or is out. After putting more paper or straightening the paper out after a miss feeds, you usually have to press the on/off button so the printer will recycle and start printing.
Hope this helps. Bud
Jan 10, 2009 | Dell A940 All-In-One InkJet Printer
Copier paper feed problems
Dear Sir; If you can buy one call"rubber rejuvenator" ( statioary store ) to clean paper pick up, feed, stop rollers may be it will work, otherwise have to replace parts ,let me know if you need it I can get it for you.
Jan 10, 2009 | Minolta Office Equipment & Supplies
Techsolutions TS-8000 runs continually when switch is on. Normally you need to feed it to start is in the on position
I have a TS2500 and it behaves in a similar fashion. It sounds like you may have a paper jam keeping the paper sensor switch turned on. The first thing to do is make sure that the container that collects the shredded paper isn't full. Everytime I fill mine up I have this problem. Emptying the bin and pulling the shredded paper from the bottom of the unit usually allows it to automatically shut off. If that isn't enough, make sure that you don't have a paper jam in the cutter rollers. The most important thing you can do is make sure the unit is unplugged before doing anything with the shredding mechanism.
Hope this helps.
Dec 09, 2008 | Tech Solution TS-4500 Shredder
Fellowes paper shredder
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Jan 08, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Problem ts 6000
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Nov 30, 2007 | Tech Solution TS-6000 Shredder
HP PSC 1210 All-In-One InkJet Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
