Question about Krups 203-42 Electric Blades Grinder
My krups coffee griner won't grind coffee. the blades turn but it does not grind anything.
4 Suggested Answers
SOURCE: Krups coffee mill
To disassemble the Krups 203B grinder locate the four recessed clips which snap into the base. Tip the unit over and look at the base. I was not able to unsnap these without damaging the clips. Once the clip ends were removed the base and top separated easily. The AC cord is soldered to two connections. The cord was easily shortened and resoldered solving the intermittent power problem. The base and top were reassembled and a small amount of glue in a few locations secured the base to the top.
Posted on Oct 31, 2010
SOURCE: Krups 203-42 Electric Blades coffee grinder
i HAVE THE SAME QUESTION.
Posted on Feb 07, 2008
  • 67 Answers
SOURCE: Krups GVX2-12 Electric Burr... Problem:
First, unlock and unscrew the upper burr carrier. Clean and check the upper burr by gently running your finger over the teeth in the cutting direction. It shoild feel moderately sharp. If it feels very blunt, look at the teeth under a good light. If you see a substantial "flat spot" at the top of the teeth, probably the burr set will need replacement.
For the bottom burr, clean carefully its teeth, and the entire area in which it is housed. Include the outlet orofice as well. You may find a lot of oily deposits within here, so just clean them off as best as possible.
When all is clean, insert the top burr holder back in place. Screw it down until both burrs touch, then back it off (say) 1/4 turn, and lock.
Put some beans in the top, and switch on. Adjust the top burr until the desired grind is obtained.
The ground coffee should feel like a coarse sand when close to the desired grind size.
Posted on Mar 14, 2008
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
May 05, 2013 | Krups 203-42 Electric Blades Grinder
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
I set up our new coffee maker and it didn't grind...ordered it online from Macy's but had no manual and didn't know what to do...put coffee grinds in the top and then set up the timer for this...
You need to swivel the brew basket cover until it locks for the coffee to grind. Then turn the machine on and the coffe will grind. , then turn the machine off, add water and press the auto on to use the auto timer.
Dec 13, 2009 | Krups KM7000
Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Krups xp4030 wont push espresso thru and when you
I had the same problem. The metal filter is clogged with very finely ground coffee. To clear the filter, boil it in vinegar and let it sit for a few hours. Rinse the filter and run water through it in the machine (no coffee in the filter). I found I had to grind the coffee at the medium setting in order to keep the problem from recurring.
Aug 05, 2009 | Krups XP4030 Espresso Machine
Krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
May 25, 2009 | Krups Coffee Makers & Espresso Machines
How i can take the griner out to clean. I lost my manual.
Hi
When you use pre-ground coffee make sure that you use just 1 level scoop. Never use a heaping scoop as it will either kick the coffee out and not make anything or will break your brew drive.
Apr 23, 2009 | Saeco Royal Professional Espresso Machine
I bought a Krups GVX2 coffee grinder and am not able to get it to work. I have followed the instructions "to the letter" but once it's plugged in and switched on, the "on" switch on...
I know that this machine is sensitive with the lids needing to be securely fastened (both the top and the plastic catch bottom container) maybe that is it.
Jul 14, 2008 | Krups GVX2-12 Electric Burr Grinder
Krups 203-42 Electric Blades Grinder Logo
95 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
