Question about Boss AUDIO SYSTEMS BV7300 Car DVD Player
BOSS 7300 in dash DVD player, when playing a cd it will just stop playing and the screen will flicker between a blue screen that says "media" at the top & the radio display screen. What is the issue? Also I want to bypass the parking brake wire. Do I tie it into the ground wire from the car's wire harness or ground it to the deck's metal casing with a screw? aowens82@live.com
    President:
  • 2,047 Answers
The flicker which happens is as a result of a power failure in the unit. Whenever this power fluctuation occurs it causes the unit power to go off and then restart. The restart is what brings about the screen which displays media at the top and the radio display screen. try tracing the cables which supply power to the unit for any inconsistencies to sort this out. Also you can check te use which affects the supply of power to te unit.
Here are 2 links to help with bypassing the brake. The first is a video while the other is a detailed step by step explanation.
http://www.youtube.com/watch?v=NgdfLst2QvQ
http://www.ehow.com/how_7265002_bypass-brake-wire-dvd-player.html
hope this solution has been helpful?
Posted on Mar 27, 2011
DVD Bypass Codes w/ NO SWITCH
1- put dvd inside the video player
2- wait for blue screen to pop up and you should hear music begin playing
3-press stop twice on your remote
4-enter the code 26604
Dec 19, 2012 | Dual Xdvd8181 Cd/dvd/mp3/wma Motorized 7"...
I have 2002 cwrn vic and i bought boss 7300 i got all speaker wire hooked up..were i hook up battery yellow cord and trouble with making shure im doing this right..
Yellow wire should be hooked to the constant hot wire in your dash. If you check your wires with a multimeter (if you have one), with your key out of the ignition, you will find it....Only one should have voltage when key is in off position.
Oct 07, 2010 | Boss AUDIO SYSTEMS BV7300 Car DVD Player
MY BOSS BV7970 DO NOT PLAY ANY BURN CDRW OR DVDS
Some players are picky with certain cdrw/dvdrw discs. You might have to experiment with different brands/types for your discs. I used to have a cd player (teac) which would just refuse certain brands cd-r discs but play others just fine. I know it sounds odd, but once I noticed which ones work and which ones don't I never looked back.
Also, have the "problematic" discs been recorded on just one recorder? Have you tried playing discs recorded on a different recorder?
Also - I'm sure you've already tried it-it's always a good idea to clean the laser just in case.
Hope this helps+
Good luck,
Raf
Nov 13, 2009 | Boss BV7970 CD Player
MY in dash dvd player with flip open screen doesn't open
in dash flip tv dosent come allthe way out
Oct 29, 2009 | Car Audio & Video
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
I have a Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player i can play music on it ,wen i insert a dvd the screen goes black i can hear the dvd playing on my speakers but no picture comes...
there is a safety brake wire that needs to be hooked up. If it was installed professionally, have them explain it to you.There is not supposed to be any video players in view of the driver while in motion. Stop your car and put on the parking brake. If you installed it yourself, you probably didnt hook up the wire. Look inthe install manual for DVD safety wire.
Dec 21, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
Dual-in-dash dvd player/ receiver with
The revised cord is simply a ground wire just splice it to you ground wire and you can have the video playing while you are driving try not to watch it while your driving though
it is a yellow and blue cord i have this Sterio and soled the problem the same way i discribed if you want to be able to turn the screen off for any reason you can hook up a switch in the yellow and blue wire then run it to the ground wire
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Boss cd dvd player
Can you hear the drive spin? If you can, buy a cd cleaning kit and try. Sometime the laser len is dirty and the same message occur. Goodluck.
Oct 26, 2007 | Boss DVD-4200B Car DVD Player
Blue screen will not go away
The problem is that you're trying to bypass a safety feature. Newer video head units are smart enough to know when you've just grounded the brake switch wire so you can watch it while you're driving. Try hooking it up to your parking brake wire.
Mar 03, 2007 | Dual Bravo HRC-0703 DVD Package Mobile...
Boss AUDIO SYSTEMS BV7300 Car DVD Player Logo
173 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
