Question about Wolf Range RHP-6-36 12 in. Gas Cooktop
We can't turn off the igniter on our gas cook top
  • Wolf Range Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Mar 27, 2011
5 Suggested Answers
dauphine
  • 207 Answers
SOURCE: No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Posted on Apr 09, 2008
  • 222 Answers
SOURCE: why does my jenn gas cook top burners all flicker when turned off
hi im gerbee,i will sujest to clean the area were is the place of ur knob control try to remove the control knob then clean it by using a vaccium coz sometimes the problem is very dirt of the control knob.
Posted on Dec 02, 2008
Eddie Rentas
  • 59 Answers
SOURCE: Spark igniter discharging when turned off
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
Posted on Jan 11, 2009
heatman101
  • 43501 Answers
SOURCE: Electric ignition for one burner on counter top ge
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Oct 10, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Does not ignite
Check to make sure that the gas is getting to the igniter. If you can ignite with a lighter or match, than the igniter itself needs to be replaced.
Apr 01, 2009 | GE 30 in. JGP326 Gas Cooktop
Gas cook top
thanks for the question yes some stoves do this and its normal when the burner you selected lights turn to low or hi the igniter will stop they do this to save on igniter modules thanks the appliance doc
Sep 16, 2008 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Claus.
Jun 08, 2008 | Cooktops
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Wolf Range RHP-6-36 12 in. Gas Cooktop Logo
403 people viewed this question
Top Wolf Range Cooktops Experts
Michael Galve
Michael Galve
Paul Carew
ray gallant
Are you a Wolf Range Cooktop Expert? Answer questions, earn points and help others
