Question about Whirlpool RBS275PD Electric Single Oven
After self cleaning oven no longer heats up - Whirlpool RBS275PD Electric Single Oven
  • Whirlpool Master
  • 4,655 Answers
Sometimes the only way to solve this problem is to contact me or another Whirlpool Technician. Reason being Whirlpool has taken a very strict course of action when people post Whirlpool manuals here or the public on-line. I also have 5 days a week that I can contact Whirlpool if the question is a hard to solve answer. This is rare. The problem you are having is related to possibly your door lock or thermal fuse and once self cleaning begins you are having a fault that turns the power off and can only be resolved by doing a series of diagnostics. Click here and this page will explain=> RBS275PD Electric Single Oven fault Resolution.jpg I will be happy to assist you (should it come to that) and others here at Fixya. Click=> Here and fill out the capsha. after I saw your post I pulled the service manual to see if there by chance was a one answer solution and it appears that you will need to follow the instructions if you request I will send. We all love those easy answers and this will be much easier one on one, Thank You and thanks for choosing Fixya, Sea Breeze
It could also be simple as a defective=> 9759243 Thermal Fuse
Parts Manual=> RBS275PD Owners Manual=> RBS275PD
Please rate this solution, Thanks, Sea Breeze
Posted on Mar 27, 2011
Hotpoint self cleaning oven clean light won't stop blinking
might need to run it through the cycle again. you may have disrupted the timers and if has not reset itself. try this link and see if these answers help you out.
Why does my oven light keep blinking after the self cleaning cycle on my...
Dec 02, 2017 | Hotpoint Ovens
Door is locked after self cleaning
Most ovens with self-clean cycles have a door lock to keep things closed when it ramps up the the extreme heat levels for cleaning. Usually, the door will stay locked until the thermostat sensor says that the oven is back down at or close to room temperature. If you just finished the cleaning cycle, you'll likely need to wait a while longer.
Nov 24, 2015 | Whirlpool Gold 30 in. Electric Convection...
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Wall oven needs a reset- wont heat
Hello John, thank you for allowing me to assist you!
I understand your wall-oven is no longer heating. The wall-oven has a safety thermal to prevent the oven from overheating. If the unit will not bake or broil, more than likely the safety thermal has tripped. Other possibilities are incorrect power supply or faulty main control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Best regards!
Oct 27, 2013 | Frigidaire 30 in. Electric Gallery Series...
After cleaning the ovens with the self clean feature, the lower oven no longer heats up
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 l';'
Aug 05, 2011 | Thermador C272 Electric Double Oven
How do I get the door open after self cleaning and what do I push to self cleaning
Hi, Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
Instructions
Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
Lock your oven door manually if your model does not lock it automatically when you clean.
Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
Tips & Warnings
Because self cleaning ovens are better insulated, they are more energy efficient when used for cooking. However, if you run the self cleaning feature on your oven more than once a month, you offset the savings you realized. With light to moderate use your oven should be able to be cleaned every one to three months.
Save on the electricity used with a self cleaning oven by cleaning the oven right after use at a high temperature. For example, if you set your oven to clean after making French fries at 450 degrees, it takes less energy to get the oven up to the required 900 degrees.
If you have pet birds, take them out of the house before cleaning your oven. Over heated cooking surfaces, oils and fats, can create fumes that are harmful for a bird's delicate respiratory system.
Hope it helped.
May 28, 2011 | Ovens
Self cleaning oven help
There is nothing wrong with cleaning a self-cleaning oven. Now, I don't have experience with your speicific oven, but I do have experience with other self-cleaning ovens. The self-clean function simply heats the oven up really hot. The actual temperature varies but the oven will get hotter than the hottest temperature setting. What happens is that when it get that hot it actually burns up spilled food and crumbs. sometimes in mine I even see small flames. The oven usually requires you to lock it as well since the temperature will be so high. Eventually you have to clean out the burnt "ashes" which are basically the stuff you get on food if you burn it. So the answer to what happens if you clean the oven is that you get a clean oven, nothing else. It won't hurt the oven at all. As a matter of fact even if you use the self-cleaning feature you will eventually have to clean out the "burnt crumbs" and such by hand anyway. So self-cleaning oven are designed to be cleaned by hand as well. And you won't hurt it by doing so even if you did it every day.
Jun 19, 2009 | GE Profile JTP56 Electric Double Oven
Oven won't heat after self cleaning
There is a overload thermostat located on the rear of your oven that needs to be replaced.
Self cleaning operations are not recommended by this technician.
Mar 02, 2009 | Whirlpool Ovens
Whirlpool RBS275PD Electric Single Oven Logo
96 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
