How to instal the phone number ? how to put the time ? Paper size ?
    Novelist:
  • 129 Answers
What is the model #? Most of the setting can be found in the MENU option then INITIAL SETUP.
Hope this will help.
Posted on Mar 27, 2011
Kkonika minoltaprinter 363 paper not detected prperly
size detection assy stays back side of Tray.
if their tension plate moves out of position , then such issue happens.
Apr 12, 2017 | Konica Minolta Office Equipment & Supplies
Paper mismatch error
I got around this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 25, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can't Print Invitations
There is a workaround for this problem by tricking the printer.
Deny
Mar 27, 2009 | HP Photosmart C5580 All-In-One InkJet...
Paper mismatch paper size to small choose a large size
Deny
Dec 12, 2008 | HP Photosmart 8250 InkJet Printer
Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Oct 10, 2008 | Dell W5300N Laser Printer
Alarm will not clear "Supply Rec. Paper Tray: LTR, their are no jams and the cartridge is installed properly. MF5550
Check paper size
If it is ok go to print job cancel and cancel all jobs
if the error comes while computer connected printing
before click ok go to peinter properties and change input paper size to A4 and out put as match paper size then click ok .
Mar 07, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Paper jam error
your software doesn't have problems... its your printer itself or the way you put on the paper that's why its always having error....
Feb 14, 2008 | Epson Stylus Photo R300 InkJet Printer
Printing problems
check document paper size, sounds like you have changed paper size on print driver but what of the document you are trying to print? what size is that? is it still letter or have you set page size also to 4 x 6
Nov 10, 2007 | HP Photosmart A612 InkJet Printer
k24674
jasbo
jasbo
