Question about Sharper Image Audio Players & Recorders
Need a power adapter , 6,5 volts . its a cd player , radio, alarm , and zip connection. thanks
    Brigadier General:
  • 8,546 Answers
Check Radio Shack. Bring the unit to make sure the connector fits.
Posted on Mar 27, 2011
How do I make sure that my Pioneer in-dash is working before installation
If you have access to a car battery charger or other 12 volt battery source, you can twist the 12 volt memory and accessory wires together (yellow and red) and attach those to the positive voltage source. Connect the ground wire (black) to the negative source. This will allow you to turn on the unit. Now, you need to have a sound source, and at least one small speaker to test with. Use a CD (simplest) or USB stick with music, or bluetooth enabled phone, whichever will work with your radio to provide music. If you have a bookshelf stereo speaker, or even an old speaker from an alarm clock that should work fine. With your radio powered on, music playing, volume turned up to a moderate level, touch each of the radio's 4 speaker channel's wires to your speaker and make sure you hear sound. If you don't have a car battery charger handy, you can also use an electric drill battery but be sure you know which battery terminal is positive and which is negative before you connect your radio. Another source of 12 volt power may be any number of power adapters that plug into an AC outlet, but you will need to proceed with caution. Check the back of the outlet and note the DV power output, as well as the current output (measured in amperes, or denoted with "mA" or "A". You will need a few amps (not milliamps) to turn on the radio, and at least 12 volts. You'll have to cut and strip the wires, so it's important to know which is positive and which is negative before connecting your radio to the wires. Again, please exercise extreme caution. Do not short the wires together or connect them to your radio in reverse once the adapter is plugged in. Do not perform ANY wire work while the adapter is plugged into the wall.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jan 06, 2018 | Pioneer Computers & Internet
What adapter to use for for CD player Insignia ns p5113?
Hi there, Check near where you plug the adapter into the cd player, it should tell you what power input it requires - 6 volts or something, then head to your nearest elctrical store and find a replacement.
Aug 06, 2014 | Insignia Portable CD Player with Digital...
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
Feb 06, 2013 | Sharper Image Audio Players & Recorders
Need the specifications of the AC adapter for my emerson model HD9971 cd player. So I can purchase a replacement.
The player needs a 4-1/2 volt, 500mA adapter. The plug must be center positive. Radio Shack sells suitable adapters. You may also be able to find them at thrift shops or resale stores where they often have a big pile of these adapters.
Jul 02, 2011 | Emerson Audio Players & Recorders
Where can I buy a power cord for my Magnavox portable cd/cassette player?
use the player direct power from the net other wise you have to buy a adapter with the power out for your device can be used universel
look first up how manny voltage you need 6 or 9 or 12 volt if you now thad buy a adapter with at least 1 or 2 amp how more how solid they are
Oct 31, 2009 | Philips Magnavox MPC421 Portable CD Player...
My clarian car stero will play the cd player while
It sounds as if the power leads are not connected properly.
Make sure the memory lead is connected to a constant 12+ volt source, and the switched lead is connected to a 12+ volt power source that is controlled by your ignition switch.
Aduz
Feb 24, 2009 | Car Audio & Video
Ipod
On the Kenwood models that are within about 6 or 7 years old or newer, there is an iPod adapter for the head units that plugs into the CD Changer port on the back of the radio. Kenwood makes an adapter (KCA-IP500) that gives direct control and charging through the radio and several companies make aux input adapters for Kenwood radios that will connect to the iPod's headphone jack.
Sep 21, 2008 | Kenwood KDC-3024 CD Player
Radio installation in a golf cart
Each battery is 6 volts. You would have to connect to the 1st Battery 12 volts posiltive {+} side and the 3rd battery negative side[-]. Run the positive lead thru an inline 10 amp fuse , then to the radio.
Jul 22, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Nov 15, 2007 | Emerson Smartset Clock Radio
133 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
