I cannot locate the disc. - Office Equipment & Supplies
    Novelist:
  • 180 Answers
You can Visit the website www.hp.com/support and then you can download the software there
Posted on Aug 04, 2008
How do I eject the Dvd
Press the eject button on the top right-hand of the keyboard. Be patient if the disc does not pop out immediately. Try pressing the button a few times or waiting a few seconds and then press the button again. If it doesn't eject, tilt the computer with the disc drive facing down and shake it gently as you press eject.[1]
Drag the disc icon into the trash. If the eject button isn't working, locate the disc icon on your computer's Desktop and drag it to the trash can. The trash can is located on the far right end of the Application Dock on the bottom of the computer screen.
Press and hold "Command" while simultaneously pressing "E."
Find the disc in the Finder. Open the Finder, located on the bottom left of the applications dock. Look on the left-hand side of the pop-up window under "Devices" for the name of the disc in your drive. Locate the eject button directly to the right of the disc name and click on it.
5
Eject the disc through an application if it is not in the Finder. In iTunes or DVD Player, click on the "Controls" drop-down menu located on the top toolbar and click "Eject Disc." You can also open iTunes and click on "Playlists" so that the left side bar pops up. Look for the CD icon with the appropriate name. Click the eject button directly to the left of the CD name.
Jul 11, 2015 | Televison & Video
Movie stuck n apple macbook
Hi
I assume you are saying there is a disc stuck inside your machine?
• Have you tried: using the eject button located upper right on your keyboard? Hold it down for 4-5 seconds.
• dragged the Disc-image to the trash?
• if this fails you can try using the Disc tool located in your Applications folder.
• If all else fails, try restarting the machine while holding down the mouse button. This will eject discs. After the disc is ejected let go of the mouse button and the machine starts normally.
• If even this fails you will have to try manually - the "straighten paper-clip method" There is a mechanical lever at the very side of the hole where you insert the disc that can be used to push the disc out. I would reccomend to check your manual for further instructions on this.
Hope this helps
Feb 06, 2015 | Apple MacBook Mac Notebook
Where is the hard disc locate on epc 1026
If you are talking about the HDD inside your computer, Then it is located under your keyboard,Close to the bottom on the right hand side.
Sep 20, 2013 | Computers & Internet
The disc player suddenly stops playing and says no disc even if there is disc on the shelf
Your disc player has a "lens or eye" that reads the electronic signal from your disc and transform that signal into a video image and audio sound. The reason why it stops playing and says there's no disc inside is because it fails to read the signal. The lens or eye may have acquired dirt that's blocking the signal. Try to open your disc player and locate the lens located on the center of the rotating disc holder. It is very easy to locate because it is directly under the disc. It is round, very small and made of glass. Get a cotton ear bud or just a small piece of cotton, moisten it with alcohol, or nail polish remover then wipe the lens. By doing it, you are removing the dirt that may have accumulated while you were using your disc player. It is highly advisable that you switch on all your electronic gadgets at least twice a week even if you're not using them. By doing this, you are preventing your electronic devices from acquiring moisture due to heat/coldness in the environment.
Another possibility, the format of the disc that you inserted (mp3, mp4, blueray, dvd) is not compatible with your player and therefore your player was not able to decode/read the signal.
Jul 23, 2011 | JVC Audio Players & Recorders
Front disc brake assembly diagram
SECTION 206-03: Front Disc Brake 1999 Escort/Tracer Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 06/06/1998 Front Disc Brake Front Disc Brake System Components
Item Part Number Description 1 1125 Front Disc Brake Rotor 2 2B296 Disc Brake Caliper Locating Pin 3 2B120 Disc Brake Caliper 4 2001 Brake Pads 5 - Copper Washers (2 Req'd) 6 - Banjo Bolt 7 2078 Front Brake Hose 8 2W303 Brake Caliper Bolt- (2 Req'd) 9 2814 Brake Hose Clip The front disc brake system consists of a single-piston front disc brake caliper (2B120) and a ventilated front disc brake rotor (1125). The brake shoes and linings (2001) are held in the front disc brake caliper by two front disc brake caliper locating pins (2B296) and two springs. The inboard brake shoe and lining is equipped with a wear indicator that makes a squealing noise when the brake shoes and linings are worn beyond recommended use.
2010&c18=modelyear&c20=n41287&c35=wsm%2cfront%20disc%20brake%2csxf%2c206-03%2cdescription%20and%20operation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=428&ct=lan&hp=n&[aqe] ddll111_28.gif
Dec 15, 2010 | 1999 Mercury Tracer
NEED NEW VELCRO DISC PAD SANDING DISC WAN`T STICK
http://www.hitachi-powertools.co.uk/locator.html
This will take you to the UK dealer locator. If you are outside the UK you will find tabs at the top of the page to direct oyu to other regional sites.
Jun 13, 2010 | Hitachi SV13YB 5" Random Orbit Finishing...
The disc tray of my Xbox 360 console does not open
If the tray does not open when you press the eject button, try to manually open it. To do this:
  1. Unplug your Xbox console from the power source.
  2. Locate the manual release button on your Xbox console.
    For most Xbox consoles, the manual release button is located in a small pinhole to the left of the eject button under the disc tray.
    For some Xbox consoles, the manual release button is located under the disc tray. It can be under the "O" or the "B" in the word "XBOX" that appears on the tray.
  3. Insert a straightened paper clip or other small tool in the hole at an angle to the left. Gently push the paper clip to try to press the manual release button and partially open the disc tray. This may take several tries. Typically, a thin paper clip works better than a thick paper clip.
    If you insert the paperclip in the hole and find an obstacle, this indicates that your Xbox console's manual release button is located in a different area of the console. Look under the "O" or the "B" in the word "XBOX" that appears on the tray. If this is the case, insert the paperclip under the "O" as outlined in step C. If you find an obstacle, insert the paperclip under the letter "B”. The manual release button is located in one of these three locations.
  4. After the disc tray partially opens, pull the tray with your fingers to fully open the tray
Sep 22, 2009 | Microsoft Xbox 360 Console
How to open tray when it don't want to open
You can manually eject the tray, you have to take the faceplate off to do this, but here is the instructions:
http://www.llamma.com/xbox360/repair/manual_eject_xbox_360_dvd.htm
Aug 11, 2009 | Microsoft Xbox 360 Console
Sis 7012 audio driver cannot install
The way to install is when you are asked
1.contact internet
2.have disc
3.install from specific location
choose the bottom option.
Then click the box have disc and then go to the location of the file(dont have to be on disc) and install.
Been trying loads of different ways for a week and eventually got it
Dec 12, 2008 | Computers & Internet
Xbox360
Depending on the type of disc drive that you have in your Xbox 360 console, use one of the following methods:
Method A: Insert a straightened paper clip or another small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paperclip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method B: Insert a straightened paper clip or another small, stiff wire into the second hole from the left side of the disc tray. Push the paperclip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method C: Insert a straightened paper clip or another small, stiff wire into the into the hole that is directly under the "X3" in the Xbox 360 label on the disc tray to release the disc tray. The hole is located about one inch from the right edge of the disc tray.
In each case, make sure that you line up the paperclip or stiff wire to pass through another notch behind the hole on the console casing.
Oct 17, 2007 | Microsoft Xbox 360 Console
23 people viewed this question
jasbo
jasbo
