Question about Maytag Appliances Over-the-Range Microwave Oven
Error code SE on Maytag Microwave - Maytag Appliances Over-the-Range Microwave Oven
  • Maytag Master
  • 6,771 Answers
The error code SE stands for " Systems Error " which indicates there is a short in the keypad membrane causing the system to lock up. The only option is to have the keypad replaced for normal operation.
Posted on Mar 27, 2011
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag Microwave Problem
* * * UPDATE * * * UPDATE * * *
It took a while and a look at several brands, but the -SE-error is a shorted keypad
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 21, 2008
SOURCE: Maytag microwave that has a code of 5E or SE. The
I have the same problem. Did you get an answer? Thanks. l issa
Posted on Jun 21, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: My Maytag microwave has error code "SE" on the
SE error means you have a shorted membrane keypad.
The full model number would be MMV1153AAB or MMV1153AAW and denotes color.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly ("control panel/switch" as it's called) which comes with a new keypad.
It's actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Some connectors have a lock:
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can get the part from the Pros here. They're our favorite supplier.
You can also find helpful exploded view diagrams at that link.
Posted on Apr 29, 2011
KevinWhite
  • 1902 Answers
SOURCE: I have maytag over the
Hello & Welcome to FixYa
SE or 5E means shorted keypad and to solve this problem the keypad needs replacement,
PART NUMBER: W10258190. Please get back to me if you have any other questions.
Kevin
Posted on Aug 10, 2011
Why does my microwave not work? It displays what I believe is an error code.
. The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
-korrinA S
Mar 03, 2015 | Kenmore Microwave Ovens
Maytag Microwave over the counter -error code SE
Banging on the control panel got it working would indicate a bad connection inside, not a short. Could be anything from a bad wire connection to a cracked solder joint on the main board.
Aug 23, 2017 | Microwave Ovens
Maytag Microwave mmv4203ds00 SE Error code
Not always is in the keypad the problem,in my work the problem was in one of the connectors in the control board.Resolder the contacts and it'll be fine.
Nov 22, 2011 | Microwave Ovens
Error code -SE-
Hi maaki41,
The error code SE stands for a keypad is held down for longer than 10 seconds. If you were not holding down a button then you have a defective key pad because of the sensor error. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 17, 2011 | Maytag Over-the-Range Microwave
Apr 27, 2011 | Maytag MMV1153A Microwave Oven
Screen displays -SE- , none of the keypad buttons work
The word -SE- , means systems error, the cause is a short in the membrane of the keypad. The only solution is the keypad must be replaced.
Mar 05, 2011 | Maytag Appliances Over-the-Range Microwave...
SE is written across the screen it wont turn on.
You will need to get a Maytag repairman, this is a systems error problem caused by a faulty systems control board or it has detected a problem in the microwave oven.
Jan 26, 2011 | Maytag MMV5208W Microwave Oven
Jun 08, 2010 | Maytag MMV4203D Microwave Oven
prototech@usa.net
Feb 19, 2008 | Microwave Ovens
Maytag Appliances Over-the-Range Microwave Oven Logo
12,669 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
