Won't spin everything else seems fine - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Mar 27, 2011
The air con won't work. How do I fix it, everything seems to be set up fine. I thought all I had to do was turn it on and the air con would turn on, but it won't
Check that the master switch on the external condenser fan housing is turned on, it is a sliding button like switch.
Feb 25, 2013 | Heating & Cooling
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
I have a GE Adoration WHDRE526E1WW top load washer. It drains and hits spin but will not spin. Lid switch seems to work. When tested the motor kicks on but will not turn the tub. Few times I manually spun...
It really sounds like the belt. You say it's in good shape but if it's loose or shiny from not having proper tension it wont have enough friction between the belt and pulley to actually work. If you've ever tried to move the drum when its full of clothes and water you know how much force id needed to function. Double check that belt tension and working surface.
Aug 13, 2017 | General Electric Washing Machines
Maytag washer stops during spin cycle
it seems like aproblem w motor maybe need to acouple of new carbon brush to fit in motor
i think that because it seems to me from your words that the motor only works w no load
thanks
Jul 11, 2009 | Maytag Dependable Care LAT9706
Dryer won t heat 100 74732400 model
dryer element. Common problem easy repair.
Jun 07, 2009 | Kenmore 74732 Gas Dryer
Outside compressor fan won't spin without a nudge
either you can lubricate it by spraying wd40 on the bushings. Although usually fan motors are permanently lubricated there are still dust particles that get through and cause it not to spin.
May 21, 2009 | Carrier 38CKC024 Air Conditioner
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
