Question about GE GSH22JFR Side by Side Refrigerator
We have a GE TFX24 R 23.5 cubic ft refrigerator. There is water on the floor on fresh food side of the refrigerator. We have checked the ice dispenser and ice cube supply line and cannot locate the source of the leak. Any suggestions. It is too old to spend money on a service call
peyton32034
  • 410 Answers
SOURCE: GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Posted on Dec 16, 2007
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
  • 65 Answers
SOURCE: Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Posted on Feb 16, 2008
  • 110 Answers
SOURCE: GE side by side not very cold on fresh food side
there is one of two thing that could be going wrong here ; you may have a bad evap fan mtr and control board or yourr damper is not opening properly. i would say you have the later of the two due to the fact the rf is still making ice. one thing that causes this issue is too much weight in the door causing the door to lean and not trigger in door light switch or the switch itself is damaged. the door hinge and camm assembly can be adjusted from the bottow using a standard socket set
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Jun 13, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
Need the cubic ft for a year 2000 GE
Do you have a model number?
Jan 31, 2015 | Refrigerators
GE side by side water dispenser not working very well.
you need to change the filter, located in upper right hand corner of fresh food section. Order it at geappliannce.com
Oct 10, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Hello, my ice maker is not producing ice, also, there is no water flow for cold water. I checked the water connection, it is charged. Can you recommend a solution pls.? My fridge is a HotPoint...
What about water filter? Is clogged? It is located in fresh food side in back righthand upper corner. also the holder me be bad. You can bypass the filter assembly By going in back of fridge. Hook incoming water to water valve to test. I hope this helps.
Aug 29, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Not cooling 1/2 the refrigerator and freezer
If the lower section of the freezer is whats freezing and not the upper portion, or fresh food section,what you need to check is the fan in the freezer to see if its running to circulate the cold air
Gene
Aug 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Can you adjust the temperature on the water dispenser?
The water for the dispenser comes from a reservoir in the fresh food section behind the crisper drawers. So the only way to make the water colder is to turn down the temperature in the fresh food side of your refrigerator. The water dispenser is designed to dispense chilled water, not ice water. hope this helps.
Jan 04, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
How do I find my model number
On a GE open the fresh food door and it should be on bottom right front corner
Apr 18, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
The ice maker doesnt work, and in the day several times appears water in the floor, in the side of the door of the ice maker
Uplug refrigerator and remove the ice maker so we can look at the tube that comes into the back of the ice maker. It maybe the ice maker is calling for water but ice or a crack in the tube that delivers the water is being deverted to inside the freezer area. Also look behind the fresh food compartment door and see if you can send me the model number so I will be able to go over the correct model. Let me know, Thanks, Sea Breeze
May 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE side by side Profile Performance.. water freezes on the floor
hmmm could be a really bad defrost problem but we will most likely find that the drain is plugged..... i recommend taking the food out and turning the machine off overnight if you can
May 06, 2009 | GE Profile Performance 25.2 cu. ft....
GE fridge: Freezer working but fresh food side not cold
The problem is the refrigeration evaporator, located in the freezer section is blocked with frost and ice and not air can pass through it. Four different failed parts can cause this problem. The defrost timer, the defrost heater safety thermostat, the defrost heater, or the evaporator fan motor. Unless you are very good with a volt-ohm meter, it wiil be difficult to distinguish which one of these parts has failed. A qualifed refrigeration service tech or a good appliance service tech with a refrigeration certification can find this quickly.
Jan 13, 2009 | GE 22.0 Cu. Ft. Side-by-Side Refrigerator...
GE GSH22JFR Side by Side Refrigerator Logo
360 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
