Question about Kenmore Dishwashers
My kenmore ultra wash dishwasher wont fill with water i checked the float it seems ok what could be wrong
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Mar 27, 2011
What can be wrong with my kenmore quietguard dishwasher if it does not fill with water
Most likely is is a stuck float or float switch. Next most likely possibility is a loose or broken wire going to the water fill valve. For some reason, mice seem to be attracted to this wire (usually 2 thin brown wires) - check for mouse droppings and look for chewed-through wires. Finally, if everything else seems okay, it is probably a bad water fill valve.
Sep 07, 2014 | Kenmore Dishwashers
Float in dishwasher not recognizing water level
Hi. The float sensor is just a fail safe device to prevent the DW from overflowing. I would first check the incoming water pressure and also check the input water valve to make sure that the screen is not clogged. Try running it without the water pre-heat feature also. BTW, it should be connected to the Hot water line.Temp. sensors will cause erratic problems in this case. Hope this helps.
Sep 29, 2017 | Kenmore 24 in. Elite Built-In Dishwasher...
Dishwasher Mod 587.14419400 no power to fill valve
Check the float (make sure it's free to move up and down) and check the float switch.
Jul 25, 2012 | Kenmore Dishwashers
The dishes on the top are not getting clean. Wondering if there is something wrong with the top spray arm or ultra flow water feed tube.
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Kenmore Dishwashers
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
My Kenmore Portable Dishwasher model number 665.17769K600 will not fill with water, I have to manually fill with water and it will then work. What could be causing this?
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Kenmore Dishwashers
Hello I'm looking for advise on my 11 year old dishwasher. It's a kenmore ultra wash model # 15812. The problem is that when you push the wash button nothing happens. The drain funtion still works and all...
Hello there:
To be honest with you i would first try these solutions and see if they work cause a new machine would cost a lot of money.
But if you can fix yours it would cost a lot less so plese try these solutions that i have provided below first ok?
If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jun 30, 2010 | Dishwashers
Upper tray does not wash clean, bottom does
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 10, 2010 | Kenmore 24 in. 15782 / 15784 / 15789...
Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Jun 29, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwaser does not fill
Hi. You can test the fill valve for voltage. If it is getting 120V and n water is coming in, change the valve.
Some models you can pull the float out.
When you lift it up and down, can you hear it clicking?
Please let me know if I can assist you further.
Vic
May 30, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
194 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
