Question about 2wire (2701HG-B) Wireless Router
Does the gateway 2701HG-b support WPA-PSK security the label says WEP I need WPA
  • 38 Answers
Yes, the gateway 2701HG-b supports WPA-PSK. Refer to user's guide here:
http://www.2wire.com/pages/pdfs/2701HG_user_guide.pdf Pages 25 to 28 will clearly show you how to set up WPA-PSK. Hope this helps.
Posted on Mar 27, 2011
Finding your WEP key
Samantha, ...
the only security methods supported on your N300 Router are WPA-PSK, and WPA2-PSK. The WEP security (you mention) is not supported by WPS. Go back into your settings and choose WPA or WPA2.
Feb 09, 2013 | NetGear N300 Wireless Router
Decoder description wep wpa psk to work to overide wi-fi system
ok, WEP, WPA and PSK are all wi-fi security protocols. They are designed to restrict access to your wi-fi. I would not by pass them.
Nov 11, 2011 | Zyxel P660HW-D1 Router
I tried to change from WEP to WPA but the password will not go through. It makes it an unsecure line for wireless. What am I doing wrong?
The Short Answer:
Your password might not meet criteria. It also depends on whether you use a custom encryption key. If so, then you either need to create a 10-digit or 26-digit hexadecimal number (numbers 0-9 & letters a-f) depending on whether you use 64 or 128-bit encryption.
The Long Answer:
A WPA password must be between 8-63 characters long, and must only contain ASCII printable characters.
The 2Wire User Guide for the 2700 states the following:
"You can customize the following wireless settings in the Wireless Security panel.
1. From the Authentication pull-down menu, select an authentication setting: WEP-Open, WEP-Shared, or WPA-PSK.
Note: WPA-PSK authentication is supported only on HG model gateways.
Open authentication allows users to configure their wireless adapter as either Open or Shared; in either case an encryption key is required. Shared authentication allows users to configure their wireless adapter for Shared authentication, which requires an encryption key. WPA-PSK requires that users configure their wireless adapter using TKIP.
2. To use the encryption key that came with your gateway, click the Use default encryption key radio button.
To create a custom encryption key, click the Use custom encryption key radio button. If you select Use custom encryption key, you can define a 64-bit or 128-bit encryption key. For 64-bit encryption, enter a 10-digit hexadecimal number. For 128-bit encryption, enter a 26-digit hexadecimal number. A hexadecimal number uses the characters 0-9, a-f, or A-F.
3. Click SAVE"
May 04, 2011 | 2wire 2700HG-B Router (2700HGB)
Hello, I'm trying to connect my wii wireless and it keeps giving me an error code 51330 "unable to connect to the Internet" could you tell me what it means? Thank you.
Error Code: 51330
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
Are you using WEP or WPA security on your router?
  • Log into the router using the default IP (consult your router's manual for assistance)
  • Locate the "wireless security" section of your router settings and find the WEP or WPA key.
  • If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
  • If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
  • The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
  • If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
  • If you are using WPA, the Wii console is compatible with the following types:
  1. WPA - PSK (TKIP)
  2. WPA - PSK (AES)
  3. WPA2 - PSK (AES)
But if the above information doesn't help correct this problem, then give a call to Nintendo's 1-800-255-3700 (6 am ~ 7 pm Pacific, everyday)
Feb 27, 2011 | Nintendo Wii Console
Cant get the ps3 to connect to router with password that i set up...computer does just fine
change the wireless security settings options in router Security Options None
WEP WPA-PSK [TKIP] WPA2-PSK [AES] WPA-PSK [TKIP] + WPA2-PSK [AES]try this link it might help http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Dec 29, 2010 | Computers & Internet
Error code 52030 ,when trying to hook up to wireless internet
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Mar 11, 2010 | Nintendo Wii Console
Followed instructions from Best Solution posted on Nov 19, 2009 by bhuvan25. When got to: Encryption:-WEP for wep security TKIP/AES for WPA-PSK. Network key/Confirm network key:-is the wep key or wpa-psk...
If you select WPA security mode then you can not add the network manually.
I think the OS on your computer is windows XP.
You can connect to the netwoek using the windws utility.
If you select WEP, then you can add the network manually.
Click here for more information about router and networking
Feb 16, 2010 | Computers & Internet
Error code 51330 trying to conect to the internet get so far then get this
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Feb 09, 2010 | Nintendo Video Game Consoles & Games
I need my network key to add a new computer. I went to the belkin 192.168.2.1 page but which code is my network key please?
Hello...if you have logged into your router, you can find your network key by going to Wireless > Security on the menu.
If using WPA encryption, your network key is on this page: it will be labelled Pre-Shared Key or PSK according to the manual I have. Hope this helps.
(For info: the network key may also be known as the passphrase, WPA shared key, WEP key, WPA-PSK, authentication key, or security key).
Jan 26, 2009 | Belkin (F5D7230-4) Router (587009)
2wire (2701HG-B) Wireless Router Logo
464 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
