Question about Sunbeam 4214 Iron
My wife's sunbeam microglide iron does not get hot. What could it be the problem?. Mauricio. Thanks.
I just took apart a Sunbeam iron. This is how it disassembles:
first remove the screw at the base. Next remove the moisture dial top (it should just pop off). This allows the iron to slide apart - the metal base from the top. It should slide about an inch then lift off.
My iron didn't get hot, and what I found is the gear that attaches the temp setting to the electrical was missing a tooth. Perhaps you could set the gear to permanently "ON". In my case I found out with brute force how the iron is supposed to disassemble... time for a new iron...
Posted on Jun 11, 2011
    New Friend:
There is a plus and minus button that's how you turn it on ...my problem is mine won't stay on so if anyone can help me with that I would very much appriciate
Posted on Sep 18, 2015
Sunbeam iron model gcsbcs-212 troubleshooting unit keep turning off while ironing
The iron is getting to hot internally and setting off the high limit switch. Since these cannot be repaired by design, you will have to replace the unit.
Mar 23, 2017 | Sunbeam Irons
Tip
I just took apart a Sunbeam iron. This is how it disassembles: first remove the...
I recently had a problem with the steam button. It somehow during normal use came off its track in the handle and was stuck down in the "slot". After several searches online and this site i tried a knife along all the edges trying to figure out how to disassemble the iron. Well one quick flick with my knife to the side of the steam button and it came out. Well the surprise was the screw under these buttons. Hopefully this can help someone looking to disassemble the iron when they have problems.
on Jun 11, 2011 | Sunbeam 4214 Iron
Sunbeam iron 5900 2400 watt not become hot. Now what can I do?
opps sr 5900 2400 watt have mixed consumer confidence
http://www.productreview.com.au/p/sunbeam-ultura-sr5900.html
if the dial or iron wont heat up at all
most sunbeam irons have 12 month warranty
if less than 12 months old and you have the reciept
take it back for refund or exchange
if out of warranty toss in the bin...... buy a new iron
Sep 20, 2016 | Sunbeam Irons
Sunbeam steam iron model #GCSBRS-1 does not give steam. 11/2yr old
I have had the same issue with both of these irons. I bought them both thinking they would be a "better" iron with more steam and have not been happy within the first year of owning them. Thanks for the tips.
Mar 22, 2012 | Sunbeam Irons
My wife has a Sunbeam iron handed down from her Grandmother so it is possibly fifty years or more old. It is a model A-4. The iron works well. I just want to replace the cord. How do I take it apart? I am...
try to open the terminal box then loosen the screw for line 1 and then the line 2 if you replace the cord see to ti that you wire installed is the same size on old wire.to avoid over loading.
Feb 25, 2011 | Sunbeam Irons
Sunbeam iron 4214
My iron leaks when I fill it past the fill line, so make sure you're filling it only to the fill line.
Nov 06, 2008 | Sunbeam 4214 Iron
Open Iron
on most common IRONS , theres a screw located on the back where the main cord is , underneath it , AJ
May 15, 2008 | Sunbeam Classic 3957 Iron
Sunbeam 4214 Iron Logo
757 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
