Question about Bose Wave Music System CD Shelf System
The multi disc player doesn't play the disc and reads "disc error"
  • Steve Bishop Feb 23, 2013
    I have the same issue. For what I payed Bose quality falls way short of what I expeced.\
  • Bose Master
  • 6,771 Answers
The problem is in the laser pickup assembly, overtime the laser becomes weaker until it reaches a point it can not track the cd. One option is to purchase a disc cleaning kit to clean the laser lens, that might get it working again. If that fails! I recommend contacting Bose for service because they do not authorize anybody outside of their facility.
Posted on Mar 27, 2011
2 Suggested Answers
SOURCE: Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Posted on Jun 06, 2007
Technika tv/dvd combi dvd will not play when disc inserted it reads then indicats "no disc" and when attempting to play via start control on remote signal "err" appears
your player did not read multi disk or maybe the lens is not clean try to clean it with dvd disk cleaner first or check the disk for some scratches causing problem
May 24, 2011 | Televison & Video
I put in a new disc to record and ( and get "Recording error, can not record on this disc." E 4 54039000. Seems like it doesn' want to format as usual. This just started about a 2 weeks...
E4 error code means that the disc isn't being read, because the unit is dirty or the optical eye is going out .You have to get a cleaning kit and then proceed.
you may try this:
unplug from wall, wait 15 minutes, plug back in, and reset the clock,
or
The disc must be DVD-R with an R4.7 under the logo and they MUST be 4X or 8X specific .... the cannot be 1X - 8X or 1X - 16X or note up to 16X .... the disc box must state 4X or 8X ONLY .... and yes they are hard to find for sure
Mar 16, 2011 | Toshiba DR570 DVD Recorder
My Sony DVP-CX777ES player just opens and closes several times upon powering up. Then it stops and I get an error message that reads "C 32 00." Then it turns off.
Please check door mechanism as explained in chat session and possibly loading belt and/or door switches could be culprit and causing problem.
Hope this will help.
Thanks.
Mar 13, 2011 | Sony DVP-CX777ES Multi-disc DVD Player
Disc error
how long have you been using the player. There is every tendency that the lens (laser) of your player is weak and that's why it cannot read or play DVDs.
The lens (laser) is what makes the player reads discs, and if the lens is weak/dirty, there is no way it can read or play disc.
Get a lens cleaner and use it to clean the lens, if that does not solve the problem, then its means, the lens needs to be changed completely.
Good luck.
Apr 17, 2010 | Toshiba SD-2815 Multi-disc DVD Player
Wont play blu ray discs only dvd
Are you playing original blu ray disc? Is your player capable of reading multi-format. Read your manual for troubleshooting. If that won't help. Try to play original blu ray or the ones that you have played in before. It that plays that means you have defective blu ray or unreadable format. Hope this help.
Apr 04, 2010 | Samsung BD-P4600 Blu-Ray Player
Sony DVP-NS325 "Cannot read disc"
there is some problems with your optical lens that is why not spinning or reading data on disc. before change the lens adjust first the two trimmer for DVD and CD adjustment for laser beam.
Sep 09, 2009 | Sony DVP-NS325 Multi-disc DVD Player
Aiwa xd-dv370 doesn´t play lens cleaner disc
The lense of the player may have gone week, since you have been using it for a long time. Replacing lense will be a solution to this.
Jul 09, 2008 | Aiwa XD-DV370 DVD Player
Bose Wave Music System CD Shelf System Logo
140 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
