Question about Roper RAS6233KQ Top Load Washer
Got a Roper washer leaking all the time other than when it is spinning out?
    Sergeant:
  • 170 Answers
Pump
Posted on Mar 27, 2011
My washer leaks when it rinses and spins
Remove the case and defeat the lid switch for testing. Do a load and see if you can tell where the leak is. Most times the pump is the leaker. A very easy fix.
More here
Jul 29, 2010 | Roper RAX4233PQ Top Load Washer
Leaks when the washergoes into the spin cycle.
Could be crack on underhose or possible drum fault
Sep 30, 2009 | Roper RAS6233KQ Top Load Washer
Roper washer will not spin water out.
This washer is made so that it can be easily repaired where it sits. the case can be removed and you can jumper the lid switch to run the machine with the cover off so that you can spot the leaks. Here is an excellent page on accessing this machines innards.
Click HERE
Feb 27, 2009 | Roper RAS8445KQ Top Load Washer
I have a roper washer that wont spin. Probably the coupler. I have changed couplers many times on other types of washers whirlpool amana and kenmore. etc. is the process the same with a roper ?
exact same as a whirlpool, for they own roper, amanas do not have couplers..... the kenmore might if the model starts with 110.********* or 118.*********
Jan 16, 2009 | Roper RAX4232KQ Top Load Washer
Roper top load leaking from pump.....any solution other then replacing pump?
replace pump it is all spin welded together and not made for repair besides you already have it off $45-50 will finish repair normally costing 150-200 for tech to do
Aug 06, 2008 | Roper RAS6233KQ Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Washer will not spin or drain water
I have a roper washing machine model RAB 2121kw and about a year ago it did the same. I was at the machine when it tried to spin one day and i opened the lid and spun the drum by hand a few times then shut the lid and slowly the drum started spinning. One problem is that i have just moved the washer and i now have an oil leak. When the drum wouldn't spin i think the motor heated the oil seal on the gear case and now it leaks. I have looked into it and don't think its that hard of a thing to change.
May 24, 2007 | Roper RAB2121KW Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
