Heating & Cooling Logo
Posted on Mar 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Heil furnace model #NFCP4800B1 is only set up right now for heat but does have the capability to have air conditon. how do i know what is needed to make this happen. i have no manuals on furnace as it was in home when i purchased.please help
Robert
Level 3:
Genius:
  • Heating & Co... Master 1,036 Answers
  • Posted on Mar 27, 2011
Robert
Level 3:
Genius:
Answers
1036
Questions
8
Helped
345526
Points
3136
Hello, in order to have air conditioning you need a evaporator coil, a outdoor condensing unit , a line set that connects the two to each other. You will have to have a cooling load calculation done so you know what size air conditioner you need for your home, also you will need to bring power to the outside unit from the main electrical panel in your house. Let me know if you have any other questions.
3answers
Heil h9mpv075f12d1 90000 btu Turns on fine, runs 5-6 minutes at slow fan speed. Then flame shuts off. Then for about 45 seconds fan goes to higher speed. Repeats this cycle over and over.
https://diy.stackexchange.com/questions/130130/furnace-runs-for-about-5-minutes-only-and-shuts-off?rq=1
Why does my furnace run then stop? A common reason a furnace short cycles is because the heat exchanger, the part that heats your air, is getting too hot due to a lack of airflow. Once the heat exchanger overheats, it trips the high limit switch, which shuts the furnace down to protect it.Dec 9, 2016
2helpful
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
2answers
Heil furnace lights but wont stay lit 1990 model
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Heil furnance blows out cool air but not heat.
heatman101
We recently purchased a home with a heil furnace and I need to know what size filter it requires. It is a gas heil model # NUG1075DF01. Please help !
That is hard to answer but I would say that for a furnace of that size you are probably looking at somewhere around 16x20x1. On older heil furnaces they often had the filter mounted inside the blower compartment so if the case you can just remove the cover and measure it. If not it should be located on the return air duct close to the furnace. Hope this helps you some. Thank you.
Top Heating & Cooling Experts
Paul Carew
john h
