Hello I have a Coship CDVB9200A which needs a new power supply board aparently the manufactures (so I was told) does not supply parts. Any ideas on where I get get another board ?
  • 822 Answers
Try ebay...................or amazon...............
cheers
Posted on Mar 27, 2011
Pride pursuit has little power in reverse
I am not an expert on such things but I have had a little experience of a mobility scooter with a similar symptom or fault.
Speed control is by a switch-mode power supply and reverse is by circuitry and relays (or SCR's) that change the polarity of the supply.
The fault on Sam's just-out-of-warranty scooter was caused by an electronic fault in the polarity change circuitry, which was just a small part of the large single circuit board. I approached the manufacturer who told me no repairs were possible and a complete new board would have to be purchased at a huge cost.
I argued the point on behalf of my customer and finally a new board was sent free of charge which put matters right.
I fully expect your problem is likely to have a similar cause, though you might be fortunate enough to be able to obtain circuit diagrams for local repairs, a manufacturer repair or a refurbished board at a reasonable cost.
A possible cause of such faults might be the weakening effect of electricity surges in the supply during battery charging. It would be wise to only charge the batteries when a surge protector is used in the mains supply, such as is recommended for all mains powered electronic devices including computers.
I hope this helps.
May 30, 2016 | Pride Health & Beauty
Not getting signal
is there no auto tune option in your set?
May 02, 2008 | Televison & Video
Hello there! Got an old Philips plasma tv 42PF9945 with Samsung power supply LJ44-00049A that seems to be dead. LED's are off, there's no stdby voltage, all it's doing is a very silent sound...
U searches and look at all the capacitors components on the power supply board for dying and dead capacitors yet,these capacitors are dying or dead it is alway bulges up or puffing up on to it tops.These capacitors must be replaced if have bulges or puffing up on to it tops.If no.Power supply board have internal parts are dying and shorting out some where that why it is giving very low current to power supply board.This problems are very difficult to track it down to any perticular parts are shorting out and dying.Have to have alots tools,skills and eclectronic components thoeries to do so.Best just replaced the a whole new referbish power supply board.Try website like Ebay.com to buy one.
Jun 30, 2011 | Philips Televison & Video
I HAVE A 42" Polaroid LCD TV (TLX-04240B) that i
First, I doubt that the power supply and MB are "connected", so they likely lied to you. As far as parts go, you can get them on Ebay, probably for around bucks total for the power supply and MB. This is important, Just because the model number on the TV matches the model number on the part, it doesn't mean it is the right one...the manufacturers sometimes use different boards on the same TV's. So make sure you are looking at the numbers on the boards and that they match before you buy it. Honestly though, you never know what you are getting on ebay as far as used boards and power supplies go, by the time you pay for shipping ETC you are going to be probably 150 to 200 bucks into it...and it might not work, or it might work for a while then the used parts go out as well. Best Buy has a 43" sharp LCD TV, smart, built in Roku...for 269. You might be better off to spend the extra 50 to 100 bucks and just buy a new TV, and definitely better off buying a new TV than paying some scam artist 400 bucks to fix a TV. Either way, good luck!!
Jan 04, 2018 | Polaroid TDA-03211C 32 in. LCD HDTV
I have VIZIO Model # VP50HDTV20A. While we were watching it shut off, then i call VIZIO about what happen, they told me to unblock the power then hold it the power switch for a min then try to block in...
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jul 06, 2017 | Vizio P50HDTV10A 50 in. Plasma HDTV
Copier Sharp AR-405 Plugged in but doesn't go on
Hello sir; When you switch on , does control panel light on ?if not ,check the power switch, or the fuse on power supply board.
Mar 08, 2009 | Sharp AR-M205 Copier
Tatung wont turn on
I have v30dmtt 29 inch tatung and had the same problem. I took the power supply out and took it to repair man. He told me it couldnt be fixed. I contacted the manufacturer and had a new one sent. The phone # is 915-771-7554 but you need to call 1-888-482-8864 to get a case #. It costs 70.00 for a new power supply unit.The part # I needed was 6693006610. I hope this helps.
Sep 08, 2008 | Tatung V23CLTT 22.92 in. LCD Television
Power supply
I do not have power supplies for sale, I repair them. It seems that is not easy to find service parts as the manufacturers of these LCD do not manufacture new assemblies for servicing.
If you need further assistance, write an email to jah2mil@hotmail.com
May 29, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
FLAT PANEL TV
Hello, there is a possibility that the power supply is broken. Replacement of the complete power supply board Part number: 146872116 will cure the problem. Best regards, Arpi
Mar 22, 2007 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
