Trying to find a manual for a Peavey Model PME-4 4 band parametric equalizer. Thanks.
5 Suggested Answers
  • 32 Answers
SOURCE: The settings on my Peavey Q215FX dual 15 band
Assuming that you eq is installed in your system correctly add a source like a cd of the type of music you will be putting through the system. Now starting at 0 on all frequencies adjust to your liking. Try to avoid going above 0 as much as possible because this will be adding to that particular frequency and could damage your speakers if done incorrectly.
If there is too much bass lower your sliders to the left. If there is not enough highs boost the sliders to the right up to about half way then start decreasing the bass to get the desired effect. Small increments is important.
I found that if you go to your local music store the people there are more than willing to help you.
Posted on Jan 26, 2010
  • 25 Answers
SOURCE: i have an urban audio
INPUT: Yellow (left front), violet (left neg), green (left rear), Blue (right rear), Brown (right neg), Gray (right front)
OUTPUT: Front Left pos (green/red) neg (green), Front Right pos (gray/red) neg (gray), Left Rear neg (brown) pos (brown/red), Right Rear neg (white) pos (white/red)
dfsanchez@yahoo.com
Posted on Apr 26, 2011
  • 11800 Answers
SOURCE: I bought a used Kenwood
First of all the 8W3 is a subwoofer with 2 coils that must be connected to the same amplifier, not a dual voice midrange speaker so it can't be used in combination with 2 tweeters - you will need genuine, separated, midrange speakers for that.
There is no way you can use that amp with all the others - it's only a stereo amp and the minimum impedance is 4 ohms: so if you would use it to power the subwoofers the moment the volume would get really high the amp would go in protect mode or it will simply fry.
If you still want to use this configuration you will have to connect them this way: stereo signal from the radio in the ICBM input (only the front channels from it will be used); from the front outputs to the 2 inputs on Kenwood; from the power output of the Kenwood to a pair of 2-way crossovers that you can build yourself (one for each channel)
http://www.lautsprechershop.de/hifi/aka_fw4_en.htm
or buy ready made; from the crossovers to the speakers.
Posted on Jun 21, 2011
Ngoro
  • 1144 Answers
SOURCE: Wirring diagram for Pyle ple 420p parametric equalizer with orange white and green wires
PYLE Audio PYLE Plus Series ple420p user manual
Posted on Mar 07, 2015
Hello there. I have a Peavey XR 1220 power mixer. I didn't use it for a year but now that I want to use it has all the red clip light on. I can't us it. What can I do to fix it? Thanks for your help
I don't know how your question ended up in "Computers", but I'll try to help you anyway...
I found a schematic/manual for your PEAVEY, but I think it's a just partial schematic because no power supply is shown? A link is provided below...
The manual mentions your "Clipping Indicator" but mentions only on IF DISTORTION is present. See page 21.
That LED circuit samples audio BEFORE and AFTER your "3 band equalizer". That equalizer is only shown as a "block" with no other specifications other than "CHANNEL 19 - 20". *See page 29.
In your case it appears that your CLIPPER is sensing a signal overloading condition OR that IC may be defective? And because it's only shown as a block, there may be more than one IC or many other components involved in that section?
In fact the fault may be well before your CLIPPER sensing circuit! In example a bad or leaky CAPACITOR in your power supply MAY be injecting AC into your Mixer? I've just added a SECOND link below showing bad and good capacitors.
It's difficult to say without a voltage chart or the IC DEVICE numbers known...A full schematic would have helped us both more... I hope this was of some help to you!
Armed with this manual, your broken PEAVEY and the schematic I think a good tech should be able to sniff out the problem... Look for burnt or discolored items FIRST!
Anthony
https://media.americanmusical.com/ItemFiles/Manual/PeaveyXR1212MixerManual.pdf
Good Bad Ugly Capacitors EMBEDONIX
Dec 02, 2017 | Peavey Music
How to get the whinning noise outta my radio in a f-150
Try running the ground wire directly to the battery ground.
Aug 07, 2014 | Planet Audio Peq15 5-band Parametric...
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Oct 10, 2010 | Pyramid 903G 10-Band Car Equalizer
I need a wire diagram for equalizer 903g
Jan 29, 2010 | Pyramid 903G 10-Band Car Equalizer
Equalizer setting help
try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
Apr 20, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
One out of the two microphones is intermittent.
Hi Ken....
I just fixed one of those but not for the same issue.
The manual is on the peavey site (archived)
That will tell you if there's a VOX ckt inside.
If opening the case doesnt scare you, open it ( UNPLUGGED) and reseat the ICs(integrated curcuits) that are socketed
Feb 01, 2009 | Peavey Audio Players & Recorders
How to hook the eq up??
take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
Mar 02, 2008 | Phonic PEQ3400 2x15-band Graphic Equalizer...
55 people viewed this question
 Grubhead
Grubhead
